SHG is back! Easy's EP3 goes under the knife...
Old 04-01-2011, 04:12 AM
  #1051
SHG_EasyE's Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
Originally Posted by MissShift
Skunk 2 arms any better than anything thing else on the market?
I was looking at Function 7's arms and also found this, looks interesting..
http://www.function-7.com/products/rsxrb
but im guessing it would run a pretty penny as well (even just for the arms) as apposed to skunk 2 which are pretty cheap for lca
One advantage that the F7 arms have over S2 is that they use much better bushings. You never see anyone have tear-out issues but Im not a fan of how their arms look. Im not concerned with the bushings in the S2's since Im replacing them with custom delrin units anyway.
These Skunk arms seem to be one of the best designed suspension products they make, and much better than everything but the F7's. The S2's also have an advantage over the F7's in that they use that steel mounting plate to evenly distribute load instead of just with the heads of the bolts on aluminum.
Originally Posted by Connor
Those arms look boss... I don't follow skunk2's products but looks like they have made some changes for the better. Michael Boice swears by there camber kits ahha
Yeah Ive never been a supporter of Skunk2 but you cant deny a good product when you see one ya know? This is def the only skunk2 part going on my car lol.
Old 04-01-2011, 06:07 AM
  #1052
phunhaus's Avatar
It's not about building a catalog car, it's about finding the best part for the job!
Old 04-01-2011, 06:12 AM
  #1053
PatrickGSR94's Avatar
Interesting point about those steel plates on the S2 LCA's. Looks like a nice part, except for those bushings. I PM'd Function7 to see if they have considered anything like that, since I know they do all kinds of stress modeling and testing as part of their R&D when designing parts.
Old 04-01-2011, 01:32 PM
  #1054
I just wanted to comment on Function7 LCA's (and other parts) versus others. E I know you said you like the looks of the Skunk2 arms better, and that's cool. However I asked Function7 about their design with the steel plate vs. F7's design with only the 3 bolts holding it on.
Originally Posted by Function7
It's a lot to do with material selection. The S2 arms are cast 2024 aluminum (then machined to final shape) and that requires the plate to even out the clamping force ... our stuff is billet, and we made the bolt area thicker than what was required by our initial design modeling. We supply replacement bolts to accomodate for the thicker arms as a result. The wrought aluminum is significantly less prone to cracking and allows us to save overall weight.
We model everything we make extensively (or obsessively), then run test on the cars for extended/accelerated testing. The parts come off and go through non-destructive testing (X-ray, ultrasound) to identify any design issues we've missed, so we're aware of any potential issues that may arise and revise the design. Then, we repeat the testing process over and over until we're completely happy before OK'ing the products for final release to the public.
Anyway, not knocking you choice at all. You said you like the appearance of the S2 arms better and I can understand that. Not everyone likes the "truss" look of the F7 arms. And since you said you're going to replace the bushings anyway with delrin units, there should be no problems there. The steel plate on the S2 arms is a good design choice, I think, based on the materials used, but since F7 arms are designed differently and with different materials, a similar plate under the bolts is not needed.
Old 04-01-2011, 03:36 PM
  #1055
SHG_EasyE's Avatar
For sure
Good info, thanks for the post man. I had no idea they were cast then machined. There is no doubt that the F7 is a better quality part, Ive always loved all their stuff because of all the R+D that goes into something before they release it. I remember reading somewhere that they tested and played with the design of their first set of control arms (EG/DC) for like 3 years before an official release.
Like you said though the S2's will be fine for me, and the design is definitely one of the better of whats available. Appearance was a big factor for me and thats why I chose them. JHP was also running a nice deal so I got them on the cheap
Old 04-01-2011, 05:56 PM
  #1056
^Sammy]!.'s Avatar
Location: 9/11/01 WTC Never Forget, United States Of America
Plus to add here the Function 7 has great customer service I bought a pair of used F7 lca's for my EL/EK the bushings on them were a bit out of place on them I called F7 told them what exactly was wrong they asked I take pictures and email them and they sent me a set of brand new replacing bushings free of charge only thing I paid was $5 for shipping
Old 04-02-2011, 04:02 AM
  #1057
stuartcivic10's Avatar
Car is looking good. Is it just the SIR engine or have u upgraded to a DC5 ?
Old 04-02-2011, 04:35 AM
  #1058
SHG_EasyE's Avatar
Just the stock k20A3 for now. I have a DC5 engine tucked away but it's going to get some work done over the next year or so before it goes in
Old 04-05-2011, 04:07 AM
  #1059
SHG_Mike's Avatar
subscribed
Old 04-07-2011, 04:44 PM
  #1060
crazyjetsfan22's Avatar
Evan have you used Por15 on any parts that have been sandblasted? I was going to sandblast some suspension parts and wanted to coat them in Por15.
Old 04-08-2011, 03:00 AM
  #1061
SHG_EasyE's Avatar
Yup, when I did my trailing arms I sandblasted some of the loose nasty **** off of them like around the joints and stuff. It sticks great to anything with bite like sandblasted or rusty surfaces.
So I should have some badass updates on monday. All the peices are finally coming together now. The delrin bushings were finished yesterday, and the hardware is on its way back from the plater. Should also be getting my shocks back in a week or so
Old 04-08-2011, 04:56 AM
  #1062
<StevieG>'s Avatar
right around the time I hope to finish this duct! Cant wait for the update sir!
Old 04-08-2011, 06:17 AM
  #1063
^Sammy]!.'s Avatar
Nice nice homie....can't wait to see your hatch at this years BBQ
Old 04-11-2011, 04:14 PM
  #1064
SHG_EasyE's Avatar
Just came home with a box full of fresh *** hardware! Now time to sort it all out and start the assembly process. Let the updates begin (finally)
Old 04-11-2011, 04:20 PM
  #1065
SHG_Claudio's Avatar
Im seeing tons of updates lately, what are you talking about! You must be static to drive it soon!
Old 04-11-2011, 05:48 PM
  #1066
SHG_EasyE's Avatar
Haha maybe it seems longer to me cause its just been a waiting game these last couple weeks. Im so stoked to drive the car again man, especially with this warm *** weather
Oh and were moving end of april much much closer to milford/bellingham so we'll actually be able to chill and not make hour long trips
Old 04-11-2011, 05:59 PM
  #1067
Oh **** you know what that means! No more cambodian house parties? LOL!
Old 04-11-2011, 06:29 PM
  #1068
SHG_EasyE's Avatar
Was happy to see my hardware had arrived when I got to work today
Took some time to lay it all out and make sure it was all there, plus it was a baller photo op
Remember this? So much more legit now with some cadmium plating
Then after work I got the rear calipers assembled - Threw on the new oem boots and greased the slides with some supplied niglube
Then finished them up at home
Old 04-11-2011, 06:42 PM
  #1069
Old 04-11-2011, 08:08 PM
  #1070
^Sammy]!.'s Avatar
Dam Evan that came out dope bro.....where did you get that done at?
Old 04-11-2011, 10:39 PM
  #1071
Boosted_90Teg's Avatar
I'd have laid out some black velvet to show off them suckers. Are those plated valve springs I see in there? o_O
Old 04-12-2011, 01:24 AM
  #1072
SHG_James's Avatar
x2
Old 04-12-2011, 03:53 AM
  #1073
Exhaust springs
Old 04-12-2011, 03:55 AM
  #1074
SHG_EasyE's Avatar
Thanks guys! I sent them down to a guy in florida that runs a race team that we work with when we do events down south. He gets stuff plated for his cars so he hooked it up.
We also sent down ALL the hardware for our newest Miata build at work
Those springs are for the donut flanges on the exhaust.
Old 04-12-2011, 04:55 AM
  #1075
Haylex's Avatar
so right in every way
nice camera work too!
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
