ProjEKt hatchback
Old Dec 2, 2008 | 07:18 PM
No VDUBS here in206's Avatar
Default ProjEKt hatchback
sooo... after the somewhat recent loss of my dc2 ive finally gotten around to my new project EK hatch. im a student so im a little low on money, but i use almost all of it on my car. soo heres what i have so far.
bought the hatch in the first place, cx with 166K and some chips and dents in the body, but it wasnt too expensive..
not the best pictures but i didnt have alot that didnt show the license plate..
hah but then theres the motor....
thats a problem :p
so the motor was the first MAJOR problem of the car. sohc, non vtec, 166k... you know
there was also the front end, if you didnt catch it there was a massive dent in the mood, missing grille, 96-98 front end... etc.
sooo i just happened to come across a wrecked civic si one day... :]
front end wasnt damaged, just scratches, well the bumper was cracked, but ill fix that
but it didnt but it for that.... :D
it whats on the inside that counts right??
sooo i wanted to use the interior, well and the cluster duh so i had to clean it...
it took awhile.
eventually this came though
so i threw the seats and cluster in the si, looks better, get pics up later, but then i had to pull the motor.
pulled the ugly front and drained the fluids
undid exhaust
struggled with bitch pin
undid ecu
took out battery, fuse box, radiator and coolant lines, clutch line, throttle cable
TOOK A 2 HOURS UNBOLTING THE AXLE BOLT
then popped the mounts and lifted it.
have a friend with you.
currently in the process of pulling the si motor and painting the engine bay because i dont plan on keepint the hatch the same color
Old Dec 2, 2008 | 07:25 PM
cashflip's Avatar
Nice start
Old Dec 2, 2008 | 07:26 PM
soupE__'s Avatar
Looks good man, how much you pick up the si for?
Old Dec 2, 2008 | 07:31 PM
2 grand, it a few more parts than the interior front end and motor tranny ecu etc that im using too :]
Old Dec 2, 2008 | 10:23 PM
mycarslow's Avatar
gl with the hatch
Old Dec 2, 2008 | 10:46 PM
H.I CTR's Avatar
what do you plan on doing with the si?
Old Dec 2, 2008 | 11:33 PM
parting everything from it then scraping the frame
Old Dec 2, 2008 | 11:34 PM
Originally Posted by mycarslow
gl with the hatch
thanks man!
Old Dec 3, 2008 | 05:22 AM
American.Graffiti's Avatar
Good start.
Old Dec 3, 2008 | 10:36 AM
thevtecnician's Avatar
Originally Posted by American.Graffiti
Good start.
X2
Old Dec 3, 2008 | 11:30 AM
thanks everyone, i'll have more pics up tonight
Old Dec 3, 2008 | 07:23 PM
EF9yee's Avatar
Awww, no si lip =(
Old Dec 3, 2008 | 07:27 PM
anhthong's Avatar
Looks good! Keep it up!
Old Dec 3, 2008 | 10:29 PM
H.I CTR's Avatar
why? whats wrong with the si?
Old Dec 3, 2008 | 10:31 PM
so update from today...
got a little bit done, drained fluids, disconnected vaccum lines, ecu, throttle cable, linkages, exhaust, battery, clutch line etc..
heres my little setup
started diconnecting things
oh and heres the engine bay, the undercoating didnt workout so im sanding it, it came out brown when it was supposed to be black. :[
Old Dec 3, 2008 | 10:34 PM
its totaled
Old Dec 3, 2008 | 10:35 PM
i have friday off so im dedicating all day to the car. i should have the motor in the hatch and get a decent start on the wire tuck
Old Dec 3, 2008 | 11:13 PM
Mikey Wit Da Typee's Avatar
good luck, great start, lookin to see more pics
Old Dec 4, 2008 | 10:57 AM
thnks everyone, im heading up to work on it right now, should have the swap in the hatch by tomorrow! ill post more pics tonight
Old Dec 4, 2008 | 11:27 AM
MenaceL.A.671's Avatar
Old Dec 4, 2008 | 12:01 PM
patotas's Avatar
great start, keep it up.. GL with the hatch
Old Dec 4, 2008 | 03:00 PM
kole317's Avatar
Nice! stoked to see more updates.
Old Dec 4, 2008 | 03:35 PM
poorhonda's Avatar
nice work keep the pics comming
Old Dec 4, 2008 | 05:56 PM
so today i got a hour or two in of work on the civics, but then the seattle weather took a turn for the worse and it got too cold to untorque things and play with those damn cotter pins.
I did manage to pull out the ac unit and ps. i also got the front suspension out that i was also going to use on the hatch as well as one axle, the second one was on its way to being popped out of the hub, when all of a sudden i couldnt move the hub inwards anymore and the boot of 2nd joint receded and it just didnt look good, so i think i might have to pick up a new drivers side axle :[ i have tomorow off though so i'll get alot done.
Old Dec 5, 2008 | 01:40 AM
dayum looks fun!!!
