My 88 std hatch
Hatch is going to be taking another turn, I decided to cut my losses on my sedan, and I picked up a 92 accord lx coupe, black with grey interior, 5 speed, for cheap. it's going to be my new daily, and the hatch is going to be cleaned up more and then boosted with my single slam.
I actually did work to her last night too, dropped the fuse box and started pulling out un needed wiring from a relay kit i made for my fogs and HID's. I no longer need the relay kit for my HID's, and the fog light wiring is way messy. plus I had a seperate power wire running from the battery to the relays when i could have just tapped into one of the existing power wires.
so yeah that's getting cleaned up, once the accord is dd status (has a missfire at idle and failed emitions) hatch will get my full attention and sedan will be pulled apart and scrapped this weekend
Hatch is running and driving! miss driving this thing, but damn the seats i put together suck. car has an updated set up in it, same ol a6/z6 mini me but instead of an autozone 3" intake i have a tenzo r 2.75" intake from a dc integra, a throttle body spacer, I have an ex transmission, a high flow cat, and my stock ef9 cat back on for now. also bought a Pioneer TS-W304R 12" sub from my work for the hatch, and the sound quality is amazing! hopefully this 12 will last, i keep blowing them up
Just thought i'd throw an update out there, hatch is still running well, gave her a bit of a face lift (and *** lift?) with prelude fogs, ebay clear corners (would love to get some oem stanley ones) and jdm tail lights. I fixed my passenger head lights' fitment issue, when the hood was closed it looked like the head light was sucked in about 1/4 of an inch. now if i could just get my bumper to fit better, i swear the 88's were different a different size than the 89's. i tried using an 89 fender on my car, fit terrible. my front bumper is from an 89 hatch, and seems as if it's about half an inch too wide on the sides.
any ways next mods include replacing my window regulator springs with the propper coupe/hatch lift springs that i have laying around so they go up and down smoother and quicker, welding in 90-91 floor pan rail thingies so i can install my great condition ls seats i have, and boost. I have a full kit pieced together using a dsm 14b, and adapter plate and a stock civic std manifold. all that i need left is a restrictor for the oil feed, get a down pipe made, and get my pan tapped/welded for the oil return. oh and 2 90* elbows.
any ways here's how she's sitting right now:
long term plans include an sir front, sourcing jdm/euro door panels with LHD power window switches, and a full engine bay tuck.
making baby steps towards bad ***. I want to pick up another front body harness, perhaps from an lx sedan, so the power windows, mirrors, and cruise control are integrated, as i still want to ad cruise control to my car. I also want to build a custom engine harness, that uses a mill spec harness, and that is fully independent from the body harness minus the cluster wires.
random update...
Finally dyno'd my car today. motor has about 30k on it probably less.
88 civic std
a6 block z6 head
stock bore just re honed, ring'd and new bearings
head resurfaced atleast twice...
stock internals
Skunk2 intake manifold
1" wide throttle body spacer
b18a2 throttle body
dc integra tenzo r 2.75" short ram intake with carbon fiber k&n filter
ebay 4-2-1 header
2.5" universal weld in high flow cat
2.5" half mandrel half crush bent exhaust to a jdm ebay can
chipped p28 with a b16 fuel/timing map, still pinging pretty bad -______________-
http://youtu.be/Jj3d07mBqz4
going to get a tune asap.
watch in hd for best quality. not proud of the pinging, was not aware of it untill i did the dyno run or i would have fixed a long time ago.
been spending the car actually doing stuff in my free time, like driving to the beach or floating or just being out doors instead of under my hood. this winter will see some nice updates
88 civic std
a6 block z6 head
stock internals
b18a2 throttle body
ebay 4-2-1 header
random update...
88 civic std
a6 block z6 head
stock internals
b18a2 throttle body
ebay 4-2-1 header
88 civic std
a6 block z6 head
stock internals
b18a2 throttle body
ebay 4-2-1 header
that's whp. motor is comming out this winter for a rebuild, gonna put some eagle rods and vitara's in it and finally boost this beast. also want a zc trans so i can rock equal length axles (i need a new 2nd gear and new axles any ways)
took it out of hibernation for a night to test out the newly paved roads up at vista, OMG SO NICE. my suspension is sloppy as hell though, going to work on that soon.
went to the yard today, scored a cam, cam gear and crank out of a d15b vtec, can't wait to start building up a d15 for boost, should be fun
hopefully pulling my d16 out of my car next weekend to fix some things on it and get my turbo mocked up and installed
Down pipe came today, its the last major thing other than two 90* elbows that i need for my turbo kit.
For anyone curious, my kit consists of this:
Low mileage td05 dsm 14b
450cc dsm blue tops
walbro 255
civic std exhaust manifold with a thick quality 1" steel adapter plate
stock 8ish lb waste gate
universal o2 housing flange for custom made down pipe
ebay dc integra black intercooler kit that i'm going to modify to fit my hatch
cx racing universal 2.5" mandrel bent down pipe
aftermarket J pipe
ebay ssq bov (for now, ordering tial down the road)
universal oil feed kit
small catch can
450cc dsm blue tops
walbro 255
aftermarket J pipe
small catch can
woah just checked this thread, dwils no head work afaik other than it being milled a couple times.
Black R, they are from the 90-91 prelude. installation is fairly easy, the templates on the back of the bumper don't match the prelude fogs so it's a custom cut and measure, as far as mounting goes i removed the L bracket off of the top of the pivot bracket, drilled a hole in my bumper support and bolted the fogs to the bumper support using some teflon spacers to drop the fogs down low enough
SpeedOFsmell
Apr 27, 2013 03:07 PM
Simmerman
Dec 29, 2007 06:03 PM
Jester88Si
Jul 11, 2004 09:18 PM
