GreatWave's not-so-jdm Integra build
#628
Re: GreatWave's not-so-jdm Integra build
Thanks guys I really had to play with it, the core support I bought came from a wrecked db8. Other than the hood not being quite right (probably because it was a cheap cf hood) I'm happy with the way everything turned out!
#639
All that matters is when you stop making power, thats when you should shift. And on a stock build you won't be making power high enough to worry about hurtin the motor. The only reason to rev past that high is if your on a road course and coming into a turn where you want to go faster, but upshifting will loose you time since the next turn will come up very soon and you would have to downshift.
#645
I may be in over my head on this one. I decided to try and create my own tuck harness with a factory GSR harness that I had lying around
Attachment 510585
Attachment 510585
#647
#649
Nothing to update on, really. Just found out tonight that I don't have functioning brake lights, so that'll be a lunchtime fix tomorrow. Prepping to do the valve seals, valve springs, and cams in the next couple of weeks. Going to install the S2 throttle body again, pick up a dc2r exhaust, other odds and ends.
