Civic VX the Toyota Prius MPG killer!
#126
Re: Civic VX the Toyota Prius MPG killer!
So why are you getting rid of the car? Disappointed with its fuel economy? If you're getting rid of the car because you're hearing a 'grinding noise' while driving especially after driving the car for a while (transmission warmed up) it's because of the input shaft bearing. The repair is not very difficult to do and considering that you replaced your transmission previously with a used one, I'm imagining you're annoyed you've got the same issue as you had prior to the transmission swap. (This is why doing the repair is better than a swap)
edit: Since you bought an Insight, I've got to ask, have you replaced the PCV valve on this Civic VX? Since this car will be going to a new owner and we share a mutual appreciation for cars like this, I'd say it'd be wise to replace the valve if you haven't already done so since a clogged valve can mean the difference between blowing the rear main seal, poor fuel economy and lousy performance and not... It's a cheap repair and would be helpful for the next owner of your car.
kgib808
45
12-14-2015 11:00 AM
fatchops
19
04-19-2004 07:34 PM
