**One awesome EG build!!** Tons of pics!!
Here is some pictures of a car I'm building for a little bit of track use...
Details are going to be posted as they are worked out, however as of right now they are:
Car:
1995 Honda Civic EG Si
Original CA car all stock
Autopower 6 point bolt in cage
Full repaint and color change
New undercoating
New OEM Non-sunroof roof panel
All new OEM seals, gaskets and plastics
New OEM moldings
New OEM sideskirts
New OEM cowl
New OEM front Si lip
Nothing really special, just a nice and restored exterior. No crazy rare JDM parts...
Swap parts:
HybridRacing K mounts 95a green bushings anodized black
HybridRacing Conversion harness
HybridRacing 2.9 Axles with road race grease
HybridRacing K20 fuel rail
HybridRacing K swap fuel lines
HybridRacing K swap clutch line
HybridRacing K swap full size radiator w/fans
HybridRacing K swap rad hoses
HybridRacing Ground kit
HybridRacing Shifter cables
much more to come...
Engine:
Hasn't been built yet, but it's coming... fully build K24/K20 frank, w/6spd trans.
Suspension / Steering :
Zeal Function X coilovers
ITR 24mm front sway bar
24mm Progress rear sway bar
Function7 rear lower control arms w/ spherical bearings
Function7 rear lower subframe brace
PCI spherical rear trailing arm bearings
Skunk2 Pro series + front upper A arms
Skunk2 Pro series rear camber kit
BuddyClub front ball joints
Quaife Quick steering rack w/all new OEM tie rod ends ect
New Wheel bearings
ARP extended wheel studs
Brakes:
Wilwood dynapro 6 front brake kit (w/ poly matrix B pads)
Wilwood rear parking brake combo kit
Wilwood dual pedal mount w/balance bar
Wiwood parking brake cable
Wilwood Stainless brake lines
Wilwood 5/8 master cylinder (clutch)
Wilwood 7/8 master cylinder (front brakes)
Wilwood 1 master cylinder (rear brakes)
Wilwood Remote reservoir setup
Wiwood bias adjuster ****
Motul RBF 600 brake fluid
All new stainless steel brake lines throughout the car (the car came with ABS.)
Wheels:
Enkei RPF1 16x8 +38 custom powdered coated black
Advan A048 225/45/16 Medium compound tires
Project Kics R40 lugs
Interior / Electronics:
Chasebays CM2 harness
Hondata KPRO
Custom interior switch panel
Braille lightweight battery with billet mount
Recaro Pole position seats and mounts
(gauges, steering whee, hub, ect haven't been decided)
Still have a lot of parts to order and wait on, the Zeal's aren't going to be in for a few weeks but I should have some parts arriving soon.
On to the pictures...
Remove the seats first...
I can't remember the last time I saw an EG with stock seat bolt covers...!!!
The ONLY way to properly disassemble a car. Bagged and Tagged!
WTF??
Pretty awesome photographer brochure...
Car:
New undercoating
New OEM moldings
New OEM sideskirts
New OEM cowl
Swap parts:
Engine:
New Wheel bearings
Brakes:
Wheels:
Hondata KPRO
WTF??
Re: **One awesome EG build!!** Tons of pics!!
OEM Non-sunroof panel
OEM door moldings
Misc boxes of parts
Cowl
New front Si lip and sideskirts
PCI rear trailing arm bushings...
Random parts...
Time for the underside of the car...
Fuel tank removal..
Don't forget to remove this!
It's gone!!
Had to remove the subframe to get all of the hardlines out...
The only thing that is going to be used here is the subframe, knuckles and the front lower control arms. Everything else is getting replaced.
The car is also at the body shop getting ready for paint.
Fuel tank removal..
It's gone!!
Started taking apart the main part of the cabin harness... no more ABS, cruise control or sunroof wiring.
Trash...
This is what is left.
Trash...
HOLY ****, you move fast. This is going to be a nice project once its all done. How much of the interior is going back in?
It was broke and didn't want to leak or crack. plus sunroofs are over rated
