**One awesome EG build!!** Tons of pics!!
Here is some pictures of a car I'm building for a little bit of track use...
Details are going to be posted as they are worked out, however as of right now they are: Car: 1995 Honda Civic EG Si Original CA car all stock Autopower 6 point bolt in cage Full repaint and color change New undercoating New OEM Non-sunroof roof panel All new OEM seals, gaskets and plastics New OEM moldings New OEM sideskirts New OEM cowl New OEM front Si lip Nothing really special, just a nice and restored exterior. No crazy rare JDM parts... Swap parts: HybridRacing K mounts 95a green bushings anodized black HybridRacing Conversion harness HybridRacing 2.9 Axles with road race grease HybridRacing K20 fuel rail HybridRacing K swap fuel lines HybridRacing K swap clutch line HybridRacing K swap full size radiator w/fans HybridRacing K swap rad hoses HybridRacing Ground kit HybridRacing Shifter cables HybridRacing Shifter much more to come... Engine: Hasn't been built yet, but it's coming... fully build K24/K20 frank, w/6spd trans. Suspension / Steering : Zeal Function X coilovers ITR 24mm front sway bar 24mm Progress rear sway bar Function7 rear lower control arms w/ spherical bearings Function7 rear lower subframe brace PCI spherical rear trailing arm bearings Skunk2 Pro series + front upper A arms Skunk2 Pro series rear camber kit BuddyClub front ball joints Quaife Quick steering rack w/all new OEM tie rod ends ect New Wheel bearings ARP extended wheel studs Brakes: Wilwood dynapro 6 front brake kit (w/ poly matrix B pads) Wilwood rear parking brake combo kit Wilwood dual pedal mount w/balance bar Wiwood parking brake cable Wilwood Stainless brake lines Wilwood 5/8 master cylinder (clutch) Wilwood 7/8 master cylinder (front brakes) Wilwood 1 master cylinder (rear brakes) Wilwood Remote reservoir setup Wiwood bias adjuster knob Motul RBF 600 brake fluid All new stainless steel brake lines throughout the car (the car came with ABS.) Wheels: Enkei RPF1 16x8 +38 custom powdered coated black Advan A048 225/45/16 Medium compound tires Project Kics R40 lugs Interior / Electronics: Chasebays CM2 harness Hondata KPRO Custom interior switch panel Braille lightweight battery with billet mount Recaro Pole position seats and mounts (gauges, steering whee, hub, ect haven't been decided) Still have a lot of parts to order and wait on, the Zeal's aren't going to be in for a few weeks but I should have some parts arriving soon. On to the pictures... http://i51.photobucket.com/albums/f3...G/DSC_0351.jpg http://i51.photobucket.com/albums/f3...G/DSC_0350.jpg http://i51.photobucket.com/albums/f3...G/DSC_0354.jpg http://i51.photobucket.com/albums/f3...G/DSC_0373.jpg http://i51.photobucket.com/albums/f3...G/DSC_0375.jpg http://i51.photobucket.com/albums/f3...G/DSC_0378.jpg http://i51.photobucket.com/albums/f3...G/DSC_0379.jpg http://i51.photobucket.com/albums/f3...G/DSC_0380.jpg http://i51.photobucket.com/albums/f3...G/DSC_0381.jpg Remove the seats first... http://i51.photobucket.com/albums/f3...G/DSC_0383.jpg I can't remember the last time I saw an EG with stock seat bolt covers...!!! http://i51.photobucket.com/albums/f3...G/DSC_0385.jpg The ONLY way to properly disassemble a car. Bagged and Tagged! http://i51.photobucket.com/albums/f3...G/DSC_0388.jpg http://i51.photobucket.com/albums/f3...G/DSC_0392.jpg http://i51.photobucket.com/albums/f3...G/DSC_0401.jpg WTF?? http://i51.photobucket.com/albums/f3...G/DSC_0402.jpg http://i51.photobucket.com/albums/f3...G/DSC_0411.jpg http://i51.photobucket.com/albums/f3...G/DSC_0413.jpg http://i51.photobucket.com/albums/f3...G/DSC_0416.jpg http://i51.photobucket.com/albums/f3...G/DSC_0419.jpg http://i51.photobucket.com/albums/f3...G/DSC_0420.jpg Pretty awesome photographer brochure... http://i51.photobucket.com/albums/f3...G/DSC_0423.jpg http://i51.photobucket.com/albums/f3...G/DSC_0424.jpg http://i51.photobucket.com/albums/f3...G/DSC_0425.jpg http://i51.photobucket.com/albums/f3...G/DSC_0426.jpg http://i51.photobucket.com/albums/f3...G/DSC_0438.jpg http://i51.photobucket.com/albums/f3...G/DSC_0439.jpg http://i51.photobucket.com/albums/f3...G/DSC_0443.jpg http://i51.photobucket.com/albums/f3...G/DSC_0456.jpg http://i51.photobucket.com/albums/f3...G/DSC_0460.jpg http://i51.photobucket.com/albums/f3...G/DSC_0464.jpg http://i51.photobucket.com/albums/f3...G/DSC_0467.jpg http://i51.photobucket.com/albums/f3...G/DSC_0472.jpg http://i51.photobucket.com/albums/f3...G/DSC_0477.jpg http://i51.photobucket.com/albums/f3...G/DSC_0483.jpg http://i51.photobucket.com/albums/f3...G/DSC_0484.jpg http://i51.photobucket.com/albums/f3...G/DSC_0486.jpg http://i51.photobucket.com/albums/f3...G/DSC_0492.jpg |
Re: **One awesome EG build!!** Tons of pics!!
http://i51.photobucket.com/albums/f3...G/DSC_0237.jpg
OEM Non-sunroof panel http://i51.photobucket.com/albums/f3...DSC_0001-1.jpg OEM door moldings http://i51.photobucket.com/albums/f3...DSC_0014-1.jpg Misc boxes of parts http://i51.photobucket.com/albums/f3...DSC_0019-1.jpg Cowl http://i51.photobucket.com/albums/f3...DSC_0020-1.jpg New front Si lip and sideskirts http://i51.photobucket.com/albums/f3...DSC_0021-1.jpg PCI rear trailing arm bushings... http://i51.photobucket.com/albums/f3...DSC_0004-1.jpg |
http://i51.photobucket.com/albums/f3...DSC_0159-1.jpg
http://i51.photobucket.com/albums/f3...DSC_0162-1.jpg http://i51.photobucket.com/albums/f3...DSC_0168-1.jpg http://i51.photobucket.com/albums/f3...DSC_0169-1.jpg http://i51.photobucket.com/albums/f3...DSC_0171-1.jpg http://i51.photobucket.com/albums/f3...G/DSC_0175.jpg http://i51.photobucket.com/albums/f3...DSC_0177-1.jpg http://i51.photobucket.com/albums/f3...DSC_0181-1.jpg http://i51.photobucket.com/albums/f3...G/8976d842.jpg http://i51.photobucket.com/albums/f3...G/6a11cffa.jpg http://i51.photobucket.com/albums/f3...G/515691bb.jpg http://i51.photobucket.com/albums/f3...G/26849a06.jpg http://i51.photobucket.com/albums/f3...G/39b5372b.jpg http://i51.photobucket.com/albums/f3...G/14773142.jpg http://i51.photobucket.com/albums/f3...G/fd370e19.jpg http://i51.photobucket.com/albums/f3...G/3e48bd37.jpg http://i51.photobucket.com/albums/f3...G/bac3d4e8.jpg http://i51.photobucket.com/albums/f3...G/faaae6f3.jpg http://i51.photobucket.com/albums/f3...G/56d0a2ea.jpg http://i51.photobucket.com/albums/f3...G/d2192ce3.jpg http://i51.photobucket.com/albums/f3...G/6210f048.jpg Main body harness labeled and removed... http://i51.photobucket.com/albums/f3...G/04bd4471.jpg http://i51.photobucket.com/albums/f3...G/cbd3e2f7.jpg http://i51.photobucket.com/albums/f3...G/4b7cce7c.jpg http://i51.photobucket.com/albums/f3...G/38e1b501.jpg http://i51.photobucket.com/albums/f3...G/dc9da05d.jpg http://i51.photobucket.com/albums/f3...G/bba3ce76.jpg Everything was bagged, labeled and boxed. http://i51.photobucket.com/albums/f3...G/a1d59d4c.jpg http://i51.photobucket.com/albums/f3...G/8ca9dd0e.jpg |
Random parts...
http://i51.photobucket.com/albums/f3...G/7f534d87.jpg Time for the underside of the car... http://i51.photobucket.com/albums/f3...G/85a69307.jpg http://i51.photobucket.com/albums/f3...G/c2285148.jpg Fuel tank removal.. http://i51.photobucket.com/albums/f3...G/e7798ba4.jpg http://i51.photobucket.com/albums/f3...G/c9b1e52e.jpg http://i51.photobucket.com/albums/f3...G/29f98997.jpg http://i51.photobucket.com/albums/f3...G/9475678b.jpg http://i51.photobucket.com/albums/f3...G/ecd3833f.jpg Don't forget to remove this! http://i51.photobucket.com/albums/f3...G/3a42c303.jpg It's gone!! http://i51.photobucket.com/albums/f3...G/84bab581.jpg http://i51.photobucket.com/albums/f3...G/19ddfec4.jpg http://i51.photobucket.com/albums/f3...G/784225b4.jpg Had to remove the subframe to get all of the hardlines out... http://i51.photobucket.com/albums/f3...G/393ffe34.jpg The only thing that is going to be used here is the subframe, knuckles and the front lower control arms. Everything else is getting replaced. http://i51.photobucket.com/albums/f3...G/80764f1f.jpg http://i51.photobucket.com/albums/f3...G/3403dcc8.jpg The car is also at the body shop getting ready for paint. http://i51.photobucket.com/albums/f3...G/550dadea.jpg http://i51.photobucket.com/albums/f3...G/d6217768.jpg http://i51.photobucket.com/albums/f3...G/3bfe39bd.jpg http://i51.photobucket.com/albums/f3...G/0f9cc891.jpg |
http://i51.photobucket.com/albums/f3...G/e166b4c2.jpg
http://i51.photobucket.com/albums/f3...G/e9162232.jpg http://i51.photobucket.com/albums/f3...G/3340ca65.jpg http://i51.photobucket.com/albums/f3...G/eb8ff0ad.jpg http://i51.photobucket.com/albums/f3...G/621e95aa.jpg http://i51.photobucket.com/albums/f3...G/ac823ff5.jpg http://i51.photobucket.com/albums/f3...G/fa550ff2.jpg http://i51.photobucket.com/albums/f3...G/751c001d.jpg |
http://i51.photobucket.com/albums/f3...G/122bee5e.jpg
http://i51.photobucket.com/albums/f3...G/ef8ae4f9.jpg http://i51.photobucket.com/albums/f3...G/32109261.jpg http://i51.photobucket.com/albums/f3...G/1a2cb21f.jpg http://i51.photobucket.com/albums/f3...G/151334e9.jpg http://i51.photobucket.com/albums/f3...G/7c4729d4.jpg http://i51.photobucket.com/albums/f3...G/07a97619.jpg http://i51.photobucket.com/albums/f3...G/40e31d42.jpg http://i51.photobucket.com/albums/f3...G/d19acb36.jpg http://i51.photobucket.com/albums/f3...G/a9f21849.jpg The new roof has been put in place... http://i51.photobucket.com/albums/f3...G/7f46810a.jpg http://i51.photobucket.com/albums/f3...G/d6d7476f.jpg Filled with dust... http://i51.photobucket.com/albums/f3...G/6c6cf6ea.jpg |
Started taking apart the main part of the cabin harness... no more ABS, cruise control or sunroof wiring.
http://i51.photobucket.com/albums/f3...G/34a1b409.jpg http://i51.photobucket.com/albums/f3...G/3138ad96.jpg http://i51.photobucket.com/albums/f3...G/159c8536.jpg http://i51.photobucket.com/albums/f3...G/84e4c2bb.jpg http://i51.photobucket.com/albums/f3...G/508f8e2d.jpg Trash... http://i51.photobucket.com/albums/f3...G/2d4ada28.jpg This is what is left. http://i51.photobucket.com/albums/f3...G/62301c09.jpg |
http://i51.photobucket.com/albums/f3...G/90ea39b2.jpg
http://i51.photobucket.com/albums/f3...G/a9ac64d4.jpg http://i51.photobucket.com/albums/f3...G/fcf545af.jpg http://i51.photobucket.com/albums/f3...G/IMG_6461.jpg http://i51.photobucket.com/albums/f3...G/IMG_6464.jpg http://i51.photobucket.com/albums/f3...G/IMG_6469.jpg http://i51.photobucket.com/albums/f3...G/IMG_6476.jpg http://i51.photobucket.com/albums/f3...G/IMG_6508.jpg http://i51.photobucket.com/albums/f3...G/IMG_6510.jpg http://i51.photobucket.com/albums/f3...G/IMG_6512.jpg http://i51.photobucket.com/albums/f3...G/IMG_6516.jpg http://i51.photobucket.com/albums/f3...G/IMG_6518.jpg |
http://i51.photobucket.com/albums/f3...G/567f62af.jpg
http://i51.photobucket.com/albums/f3...G/bad34d4a.jpg http://i51.photobucket.com/albums/f3...G/9fc76031.jpg http://i51.photobucket.com/albums/f3...G/7c6cc093.jpg http://i51.photobucket.com/albums/f3...G/72b5b400.jpg http://i51.photobucket.com/albums/f3...G/792ff530.jpg http://i51.photobucket.com/albums/f3...G/1954be0e.jpg http://i51.photobucket.com/albums/f3...G/fa0b860f.jpg http://i51.photobucket.com/albums/f3...G/e1ab9ad3.jpg http://i51.photobucket.com/albums/f3...G/bbedc4d8.jpg I'll post more when I can! Thanks for looking! |
:thumbup:
damn.
damn...what a tear down. :thumbup:
HOLY SHIT, you move fast. This is going to be a nice project once its all done. How much of the interior is going back in?
WOW!!!!!
Sickkk
wow great start!
Great progress man! It's nice to see all the pictures, really does show how much work you put into it. :thumbup:
woah.
(browser was choking for a while there...) |
danggggggggggggggg
why get rid of the sunroof?
damn dude, ill be watching this one!
Hell of a tear down, nearly everything I did just didnt document mine as nicely lol. Keep it clean.
Originally Posted by HatchVX
(Post 41840874)
Originally Posted by AnonymousSquid
(Post 41841967)
This is amazing, I'm Sub'd for sure!
