Whats so good about high compression?
Ok im a little on the newbie side of hooking up motors so please understand. But i just reacently bought a 92 h/b with gsr head and b16a2 block with new pistons and rods. It has a 11:3 compression. My question is whats so good about high compression motors. and do i need to replace the retainers and valves to run 40shots of Nitrous? Thanks
Re: Whats so good about high compression? (jdmRus)
Higher compression should mean a more efficient motor, which results in more power. Characteristics of pump gas are what keeps compression from being higher. I'm not sure what valves and retainers have to do with nitrous...can someone explain this to me?
Re: Whats so good about high compression? (Lsos)
higher compression and nitrous are meant for each other, he could put a 100 shot wet kit on that with a good tune and be safe, i have seen to many people do it, and today there motors are still running, nitrous just makes it burn hotter, it dosen't force anything into the combustion chambers.
Re: Whats so good about high compression? (per4mance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by per4mance »</TD></TR><TR><TD CLASS="quote">higher compression and nitrous are meant for each other, he could put a 100 shot wet kit on that with a good tune and be safe, i have seen to many people do it, and today there motors are still running, nitrous just makes it burn hotter, it dosen't force anything into the combustion chambers.</TD></TR></TABLE>
Actually in a couple ways nitrous does "force" more oxygen into your cylinders. First it has more oxygen percentage wise than air. Secondly the rapid expansion from liquid to gaseous form of the nitrous oxide cools the intake air increasing its density (which also leads to more oxygen in the cylinder).
As for what is so good about high compression, it is one way to raise pressure inside the cylinder to create more force on the face of the piston and get more power out of the engine. High compression, boost, nitrous, and any combination of the above all serve to raise cylinder pressures and increase power output as long as they are accompanied by the necessary fuel/timing adjustments that are needed.
Re: Whats so good about high compression? (mercuryfrost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mercuryfrost »</TD></TR><TR><TD CLASS="quote">You can run as high as 12.7-12.9:1 and still sqeeze 100-150. Tuning is the key.</TD></TR></TABLE>good luck with that one you do this personally?
what oct gas ??? and is the timing retarted like crazy?
maybe some c16 and some real cold plugs . .
edit: also what pistons are in there ?? wouldnt your cr in a b16a2 with a more restrictive gsr head be higher then 11.3 ?? unless your got diff pistons or the like . .
Re: Whats so good about high compression? (len)
haha, len just stumbled onto something nobody else has even thought of...camshafts.
high compression makes the engine rev up quicker, create more power, operate more efficiently, and eat a little bit more money.
Full Race A6
23
07-28-2004 04:18 AM
