VTEC Problems HELP!!!
Old Feb 26, 2008 | 05:26 PM
Jeanious's Avatar
Default VTEC Problems HELP!!!
OK well the setup is an LS/Vtec P30 pistons,B16 head Skunk2 stage 2 cams, gears,springs, and retainers. Well just recently A bolt from the inner timing belt cover came loose and made one of my cam gears and timing belt mess up. I took the head off and looked for damage, but everything was good. The only things that I replaced was head gasket, timing belt, and Cam gears. Well I started the engine up and my Earl's Oil line to the head was leaking oil and later found it was cracked and broke. I replaced it. and everything was fine. Today coming home from work I tried engaging Vtec, but the engine did not sound the same. Before Vtec would sound super loud and now I feel a less pull and the vtec engagement is just noticed. I checked for low oil or loose plugs, but everything is good. Does anyone have any idea what else it could be or what to look for. I will be checking the oil pressure real soon.
Old Feb 26, 2008 | 05:41 PM
kevinz's Avatar
Default Re: VTEC Problems HELP!!! (Jeanious)
Do a leak down test. That should answer some your questions.
Old Feb 26, 2008 | 06:43 PM
Jeanious's Avatar
Well the're is no power difference or torque. When vtec kicks in it just doesn't sound or pull the same, but the power never falls off.
Old Feb 27, 2008 | 04:50 PM
Jeanious's Avatar
no one has ever had this problem?
Old Feb 27, 2008 | 04:54 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Jeanious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kevinz &raquo;</TD></TR><TR><TD CLASS="quote">Do a leak down test. That should answer some your questions. </TD></TR></TABLE>
You may have messed up more than you know. You may have bent some valves.
miniR'Us
Apr 16, 2011 06:53 PM
95civicej1
Dec 7, 2009 11:17 AM
greddy13
Dec 17, 2006 09:53 AM
BoM
Oct 2, 2001 05:59 PM
jayson roman
Aug 14, 2001 06:48 AM
