VTEC Problem
Old Dec 5, 2009 | 12:17 PM
95civicej1's Avatar
Default VTEC Problem
I have a 95 eg hatch with a full jdm b16 swap.
I bent 2 valves in the head and had them replaced and the head checked out by a local Napa Machine Shop. Got the head back from the Machine Shop and put the head on. Test drove it and vtec worked fine the first 3 or 4 times I tried it. Came back to the house and the timing belt was loose so it was tapping the valve cover making a weird noising and tightened the belt up. After tightening the belt VTEC will not engage. I have replaced the solenoid with 2 different solenoids that i know work, have checked the wiring and its all good, have tried everything i know of and still nothing. I have a chipped p28 right now in it, but have also tried a jdm p30 so its not the ecu either.
Any help?
Old Dec 5, 2009 | 12:21 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: VTEC Problem
is the t belt on right? maybe jumped a tooth? did the shop clean the head and possibly the screen is clogged? is there enough oil in the car?
Old Dec 5, 2009 | 12:23 PM
95civicej1's Avatar
oil is fine, also i have cleaned the screen and stuff.
im gonna double check the timing today.
Old Dec 5, 2009 | 02:34 PM
JJsMotorsports's Avatar
is oil pan clean of dents?
Old Dec 6, 2009 | 06:36 AM
boosted k20's Avatar
make sure the machine shop put back the two dowel pins on the rocker arm shafts on the timing belt side of the head
Old Dec 6, 2009 | 07:15 AM
SIXTY-1HATCH's Avatar
Sounds like the timing got knocked off.... Start with the basics man, lets see, what do you need for vtec?
right amount of oil
temp reading correct, along with vehicle speed
timing set correct
make sure the screen on solenoid isn't clogged
I think thats about it, unless it is a mechanical issue like other dude said about the rocker pins. You said it seemed to work fine @ first, but if they weren't installed correct I suppose they may be able to work themselves out. I would imagine you would here it bouncin in the head though.
Old Dec 6, 2009 | 10:08 AM
95civicej1's Avatar
Checked the timing and its all good..
have cleaned the screen and also swapped solenoids, still not working.
Old Dec 6, 2009 | 09:00 PM
Do-Work's Avatar
vtec would not work with out this..and what does it look like
Old Dec 7, 2009 | 09:00 AM
its two pins that are located under cam caps closest to the timing belt side. remove these two cam caps and u should see two dowels under it. if these are not put back in, u will have vtec on and off.
Old Dec 7, 2009 | 09:49 AM
turbotypeR@SPEC's Avatar
25 Year Member
Does it have good oil pressure?
Old Dec 7, 2009 | 10:31 AM
95civicej1's Avatar
im fixing to check the oil pressure.
Old Dec 7, 2009 | 11:17 AM
Do-Work's Avatar
i just'd check'd them and the are two different sizes one is taller and has bigger holes then the other does that matter
95civicej1
Dec 13, 2009 09:03 PM
95civicej1
Dec 5, 2009 05:14 PM
Jeanious
Feb 27, 2008 04:54 PM
greddy13
Dec 17, 2006 09:53 AM
RICE POLICE SIP
20
Jun 13, 2006 07:22 PM
