Is a tapered throttlebody important?
Old 09-19-2006, 10:57 PM
* B A N N E D *
crxsiperf's Avatar
Default Is a tapered throttlebody important?
What is the difference between no tapered and tapered throttlebody ? I need a 65mm throttlebody to fit with my edelbrock intake manifold and wanna know what the difference is>?
Old 09-19-2006, 11:37 PM
salman's Avatar
BUmp, i also need the same answer,
Old 09-20-2006, 04:20 AM
type B16's Avatar
Default Re: (salman)
something about increased velocity i think
Old 09-20-2006, 07:06 AM
mgags7's Avatar
yea a taper is gonna up velocity.....
just go with an rpm service tbody....
Old 09-20-2006, 08:06 AM
JCushing's Avatar
Default Re: (bb4ever)
stock TB's have the taper...
if your looking for a replacement its hard to beat this https://honda-tech.com/zerothread?id=1624626
Old 09-20-2006, 08:10 AM
type B16's Avatar
Default Re: (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">stock TB's have the taper...
if your looking for a replacement its hard to beat this https://honda-tech.com/zerothread?id=1624626</TD></TR></TABLE>
thats what im planning
i think its 3" to 68mm butterfly
is that a good taper?
Old 09-20-2006, 09:01 AM
NathanMorris's Avatar
Default Re: (type B16)
I have a 69mm-&gt; 65mm on my D series. I'm pleased with it.
It's essentially creating a venturi which will in essence speed of velocity. It also helps that most of these are actually 3" which is what most intakes are....
Nathan
Old 09-20-2006, 09:18 AM
* B A N N E D *
crxsiperf's Avatar
Default Re: (NathanMorris)
I heard that power throttlebody has no taper , and i dont really want a billet tb , they tend to stick sometimes
Old 09-20-2006, 02:43 PM
JCushing's Avatar
Default Re: (crxsiperf)
you heard wrong, it has a 3mm taper, mines 65 at the IM end, 68mm at the intake end
pretty sure the 68mm version tapers to 70 but i dunno for a fact.
Old 09-20-2006, 08:45 PM
type B16's Avatar
maxbore has a 5mm taper, 70mm out 65 butterfly
is more taper the better?
Old 09-20-2006, 10:56 PM
Supahr_Ed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type B16 &raquo;</TD></TR><TR><TD CLASS="quote">maxbore has a 5mm taper, 70mm out 65 butterfly
is more taper the better?</TD></TR></TABLE>
are you sure you can bore a stock TB to 70mm at the opening? but im wondering the same question on the taper also...but he power is tapered, correct??
Old 09-20-2006, 11:09 PM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">pretty sure the 68mm version tapers to 70 but i dunno for a fact.</TD></TR></TABLE>
ehh....the old reverse taper trick huh??
fasterthenU
08-09-2007 01:31 PM
the reid
06-05-2006 10:07 PM
rac3r
12-31-2004 07:21 PM
DSRxMilogen
05-07-2004 03:07 PM
tygsr
01-10-2004 03:21 PM
Quick Reply: Is a tapered throttlebody important?
