skunk 2 cams
Old May 15, 2010 | 11:47 AM
HyperFlow's Avatar
Default skunk 2 cams
I just got this GSR engine and the guy told me it had skunk 2 pro 1 cams, anyways to check if the motor actualy has cams?
Old May 15, 2010 | 12:01 PM
B20vEf9's Avatar
Default Re: skunk 2 cams
Cams should be marked p1+ on the end of the distributor side of the cams.
Old May 15, 2010 | 12:23 PM
HyperFlow's Avatar
posible to check without actualy removing the cam?
Old May 15, 2010 | 12:25 PM
00Red_SiR's Avatar
All Motor Mentor
yep, pull the cam cap/seal and have a look, or the distributor.
Old May 15, 2010 | 01:13 PM
HyperFlow's Avatar
thats what i figured, its got stock cams. Hate when ppl lie to you like that.
Old May 15, 2010 | 03:20 PM
00Red_SiR's Avatar
All Motor Mentor
were there any markings on the cam ends at all?
Old May 15, 2010 | 04:02 PM
HyperFlow's Avatar
nope nothing
Old May 15, 2010 | 04:07 PM
LanierThaKing's Avatar
they may be older pro1's some of the older cams had no markings, i had some like this that cam out of wrapping like that.... best way to tell is to either measure the lift and angle of the cams, or if you cant do that just find and oem gsr cam and compare visually to see if there are any differences, slight or major.
Old May 15, 2010 | 04:14 PM
HyperFlow's Avatar
just the way this car pulled i knew it was stock cammed. i just wanted to confirm my doubts
Old May 15, 2010 | 04:15 PM
oh ok
Old May 15, 2010 | 06:18 PM
00Red_SiR's Avatar
All Motor Mentor
My old skunk tuner stage 1's had no markings on the end of the cams but they did on the middle of the cam between the lobes, that might be the only other place you could look to see if you see a letter and what it is. Pro 1's to the best of my knowledge were all marked.
Clean91Crx
May 16, 2012 08:47 PM
threehonda
K Series
Dec 20, 2009 06:37 PM
jdmcx
Jan 23, 2004 05:14 AM
camp1320.com
Dec 3, 2002 08:53 PM
evo
Dec 20, 2001 03:37 PM
