removing crank shaft
anyone have the best way to remove the crank? i have the pistons out and everything unbolted but cant figure how to remove it
Re: removing crank shaft (slowassciv33)
there are oil seals on both side of the block I belive to seal in the oil from outside, you probobly have to remove those. If you have check to make sure nothing else is holding it down and dently try to rock it out, or use a rubber mallet to help https://honda-tech.com/forums/images/smilies/emthup.gif
i do belive you gotta remove the oil pump from the block to get the crank out.....
Re: removing crank shaft (non-VTEC)
i cant get the oil pump out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowassciv33 »</TD></TR><TR><TD CLASS="quote">i cant get the oil pump out </TD></TR></TABLE>
Why? |
Re: removing crank shaft (B20C5 Turbo)
its like honda bond on and wont move
pry it off with a flathead or something similar...it will come off. It's also doweled on.
TRY HARDER https://honda-tech.com/forums/images...s/emsmilep.gif |
