RDX Injecter fuel pressure tuning
Old 07-21-2013, 02:13 AM
hksitr's Avatar
Default RDX Injecter fuel pressure tuning
those that have switched to rdx injectors. what fuel pressure have you set for tuning
Old 07-23-2013, 05:26 PM
blkSi's Avatar
Default Re: RDX Injecter fuel pressure tuning
From what I've read, it seems the base fuel pressure is 50psi and tune from there. At least that is according to Xenocron...
Old 07-23-2013, 07:19 PM
DDTECH's Avatar
On my personal racecar, I run 60psi. These injectors respond well to pressure from what I've seen..
50-60 will be fine..
Old 07-24-2013, 05:33 PM
snm95ls's Avatar
I ran stock base fuel pressure for a typical B series FPR.
I think they would have had fewer/no quirks had I raised BFP.
I would definitely run at least 50 psi BFP on them.
Old 07-25-2013, 04:03 PM
bluehbcivic's Avatar
I run mine at 60psi
Old 07-25-2013, 04:45 PM
raverx3m's Avatar
I set mine at 55 psi since that's what the rdx fuel pressure is I think
you should be fine anywhere between 50-60psi
Old 07-26-2013, 03:21 PM
Robs_B18c's Avatar
What kind of mpg's are you guys getting with these RDX injectors?
Old 07-26-2013, 06:53 PM
raverx3m's Avatar
I haven't got anything better than 30 since I smash on it constantly lol
and I didn't have any others to compare it to I built it with rdx
in the city I get about 18-20mpg freeway I get about 30
Old 07-26-2013, 07:54 PM
Robs_B18c's Avatar
I'd be happy with 30's on the hwy. Thinking about getting a set of these more and more.
Old 07-26-2013, 08:46 PM
moderator emeritus
98vtec's Avatar
I average 28-30mpg city with my h22 hatch. Fuel pressure right now is OEM until I get some time to play with the tune some more.
Old 07-26-2013, 09:03 PM
raverx3m's Avatar
on my last dyno I gained 7-9 TQ in primary before vtec.
on a hotter more humid day(20 degrees hotter and much more humid)
i increased pressure to 55psi
flanged out intake pipe to make smooth transition
removed PS
so between those 3 i gained pretty good chunk of torque in low end
Old 07-27-2013, 12:07 AM
Uncle Dave's Avatar
These injectors like ID's really come alive at 60psi and make start to make really good part throttle torque numbers with that pressure.
the.hamburglar
03-27-2015 07:58 AM
poodlemuffer
Engine Management and Tuning
02-01-2014 09:24 AM
monster_c
02-15-2012 12:31 PM
aalb1
11-02-2005 10:47 AM
Quick Reply: RDX Injecter fuel pressure tuning
