RDX Injecter fuel pressure tuning
those that have switched to rdx injectors. what fuel pressure have you set for tuning
Re: RDX Injecter fuel pressure tuning
From what I've read, it seems the base fuel pressure is 50psi and tune from there. At least that is according to Xenocron...
On my personal racecar, I run 60psi. These injectors respond well to pressure from what I've seen..
50-60 will be fine.. |
I ran stock base fuel pressure for a typical B series FPR.
I think they would have had fewer/no quirks had I raised BFP. I would definitely run at least 50 psi BFP on them. |
I run mine at 60psi
I set mine at 55 psi since that's what the rdx fuel pressure is I think
you should be fine anywhere between 50-60psi |
What kind of mpg's are you guys getting with these RDX injectors?
I haven't got anything better than 30 since I smash on it constantly lol
and I didn't have any others to compare it to I built it with rdx in the city I get about 18-20mpg freeway I get about 30 https://24.media.tumblr.com/tumblr_m...8tnso1_250.jpg |
I'd be happy with 30's on the hwy. Thinking about getting a set of these more and more.
I average 28-30mpg city with my h22 hatch. Fuel pressure right now is OEM until I get some time to play with the tune some more.
on my last dyno I gained 7-9 TQ in primary before vtec.
on a hotter more humid day(20 degrees hotter and much more humid) i increased pressure to 55psi flanged out intake pipe to make smooth transition removed PS so between those 3 i gained pretty good chunk of torque in low end http://i43.photobucket.com/albums/e3...627_211608.jpg |
These injectors like ID's really come alive at 60psi and make start to make really good part throttle torque numbers with that pressure.
