►Official All Motor Dyno Thread!
#1503
Re: ►Official All Motor Dyno Thread!
Thanks everyone! Ya, I'm pleased with the level of power that this makes on pump gas with the parts I have at the moment. The tuner recommends a better flowing IM, TB, and intake for more power. Also e85 as 12:1 is a little high to be fully taken advantage of on pump gas.
As to the rev limiter, my ideal is to have the rpm within peak power after I shift to the next gear, so I like having maybe 1500-2000 rpm or so higher than peak power if I can.
Open header did a bit better, lost about 5-10 whp between about 6100 and 7600, gaining up to 13 whp from 7600 to 9200 RPM.
Current mod list:
- B18C (GSR bottom end with B16 head)
- B16 valves
- Supertech 85lb valve springs with titanium retainers
- About 12:1 compression
- Mild port job
- Skunk2 pro 1 cams
- Skunk2 ultra street IM (was a B16A intake)
- AEM 3" cold air intake (was a 2.5" injen cold air intake)
- Skunk2 alpha header V2 (was an SMSP replica header)
- 2.25" exhaust
Blue line is a stock B16A
Pink line is the previous setup
Green line is the current setup
Red line is the current setup, but with open headers.
#1504
#1505
B16a2 172hp 112 torque B16a2 NA Stage2 Comp Cams 57200 Comp Cams springs 913-set S2 titanium retainers S2 lost motion springs B16a2 valves Brass valve guides Portflow ported head Nippon 81.5 ctr pistons Balanced crank assembly 70mm S2 throttle body Skunk2 intake manifold ported 70mm Injen air intake DC sports header Simons 2.5" cat back exhaust (no cat) Walbro 255lph pump RDX injectors Hondata v3
Mcdc2
42
01-30-2009 02:39 PM
Nick M
66
06-09-2006 09:12 AM
"NastIE Built"
06-09-2006 07:06 AM
