LS crank and rods in a GSR Block? Is it possible?
#377
re: LS crank and rods in a GSR Block? Is it possible?
why would you run ls rods and pistons? They would decrease your compression if you are going for all motor. Running an LS crank with GSR rods and pistons would raise it above stock gsr comp. while also raising displacement. best of both worlds?
#378
I doubt people running this setup is going to be using stock ls pistons. The reason why people choose to run this setup is for the small bump in displacement and you can't use gsr rods on an ls crank.
#380
try that and report back. you're gonna have some pistons coming out of the hole with gsr rods.
#381
You don't run GSR rods on a LS crank due to the above. Also changing the length of rods does not change the displacement of the engine. You can run gsr pistons on ls rods though and that will increase the compression.
#382
assumptions assumptions.. GSR "style" rods are longer then ls style rods.. I dont see what the issue would be considering the combo I mentioned would only be by about ..002 Im pretty sure the p2v clearence would be fine..
#383
... herp derpy derp derp.. no ****. did I say it did? and you will have still fallen short of a stock gsr comp.. effectively making this ordeal worthless.
#384
nevermind.. i calculated my own question..
Seems running and ITR style piston on an LS rod and crank would be pretty doable.. comp would be around 11.8:1
#385
Also GSR rods and a LS crank has been tried. With oem pistons they protrude above the deck of the block and would hit the head. You would need pistons with a lower compression height to use the longer rods.
GSR longblock and LS rods/crank=10:1=same as GSR
#386
The way you worded your statement sounded as if you were saying by installing the longer rods you would be increasing your displacement.
#387
I have pics on my profile on the same build. I used type r pistons and blocked off oil squirters, even bending out the way my crank on the counter weights still hit. Been running for 3 months and love the gains I got.
#388
Nice... that is a setup I would like to see dyno tuned.
#391
I was referring to stock comp ratios. I already mentioned it would RAISE comp with those pistons. herp derp. Doesnt matter anyway, wiseco makes a -2.40 dome piston that would make the comp on a 81.50 bore 9.91:1 which is close to usdm. And its an off the shelf forged piston. to make it stock comp on 81.5mm bore, you need a custom pr4 piston at -1.90 dome to be 10.0:1. throing in a stock ls crank rod and piston setup will not yeild stock gsr comp. as it would be 9.6:1 on an 81mm bore or 9.7:1 on an 81.5mm bore.
EDIT.. what would be cool is if, you could get a 137.5mm rod to throw in with stock pr4 pistons as that would take your comp to 10.1:1, but no one will make those unless you sell or buy 40sets lol.. just cheaper getting a custom pr4 piston set at -1.90
#392
Moderator
I am curious... "herp,derp?" What does that specifically mean?
#393
Well, if the goal is to get stock compression, I see why you're going through all this work, but most of us that have performed this particular modification in the GS-R block (by removing the oil squirters) have the desire to raise the static compression as they are usually using an aftermarket rod/piston. Not keep it to stock. I'm currently at 12.3:1, and with the fuel used on 93 octane have had no issues for several years.
#395
#399
#400
I just finished putting my bottom end together, just waiting on a new oil pump and PasswordJDM oil pan baffle to come in to finish the motor. Its an ls crank with ls Eagle Rods and Wiseco pistons.
