je 12.5.1 compression pistons too high?
#27
Re: je 12.5.1 compression pistons too high? (realis9)
Based on the website calculations, it says the je pistons have a 11.4 compression. Is this true? The je piston dome is measured at 7.4 which is less than the ctr's 8.6. Shouldn't that make it a lower compression than the ctr's.
http://www.c-speedracing.com/h...c.php
#28
i would just slap a factory head gasket and put that bitch together and fill her up with 93 and tow it to the dyno for a proper breakin and tune.
#29
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">anyone ever ran this high compression on a DD?</TD></TR></TABLE>
my old LSVTEC, was running a 12.1 compression, with a B16 head off a DELSOL
ran fine, just get some good spark plugs a range or two colder and you'll be fine and get it tuned, I can't tell the world of a difference when I got my ECU re tuned, wow!
#31
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 »</TD></TR><TR><TD CLASS="quote">Based on the website calculations, it says the je pistons have a 11.4 compression. Is this true? The je piston dome is measured at 7.4 which is less than the ctr's 8.6. Shouldn't that make it a lower compression than the ctr's.
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
dome cc isnt the only thing that determines compression. the overall compression height also play's a role.
