vtec pistons in b18b engine?
Old Apr 10, 2003 | 05:40 AM
DOHCon15s's Avatar
Default vtec pistons in b18b engine?
Will vtec pistons work in my non-vtec B18B engine. Like some ITR pistons or any other kind of piston?
Old Apr 10, 2003 | 05:51 AM
PM-Performance's Avatar
Default Re: vtec pistons in b18b engine? (DOHCon15s)
yes, rod lenght might need to be changed, but yes we haev an ls with ITR pistons in it .
I have a set of JDM itr pistons if you wnat em
Old Apr 10, 2003 | 06:07 AM
DOHCon15s's Avatar
Default Re: vtec pistons in b18b engine? (itr206)
If you can find me a set of rods that will fit on it i will highly consider buying them from you. I get my paycheck this weekend
Old Apr 10, 2003 | 06:44 AM
i wouldnt know iff hand . i think he used itr rods too . . . . let me check .
Old Apr 10, 2003 | 06:58 AM
JeremyL's Avatar
would itr or gsr rods work with an LS block and head?
Old Apr 10, 2003 | 07:18 AM
Default Re: vtec pistons in b18b engine? (JeremyL)
i think he used ITR rods.
the only thing i can do is put my itr pistons in one of our B18 blocks and assemble it to see if there are any clearnace probs, , , but thne they wont be new like they are now .
I garuntee they will work , but not 100% sure which rods, i can assume from what i know they were Type R rods.
Old Apr 10, 2003 | 07:44 AM
DOHCon15s's Avatar
I wouldnt mind if they pistons were used but if the rods and pistons dont work together you will be out of a set of pistons and rods if everything doesnt work out right.
Old Apr 10, 2003 | 07:53 AM
i was just told the LS rods should work fine with the pistons .
I mind though becuase if you dont buy them, and i try to sell them to someone else, they are used then
Call an engine builder and ask them , i would get em and try them with the LS rods, if they dont work , which i think they will , then try to grab itr rods, and they should do the trick
Old Apr 10, 2003 | 08:26 AM
Ls rods need larger Journals on thme to work. . . Supposedly the Type R ones dont work . . as per Viren , VS Racing.
Old Apr 10, 2003 | 08:44 AM
95 integra's Avatar
From my knowledge the differences in stroke means you would need a longer rod then the GSR/ITR, so I would assume using a rod for the LS would work. Now the ITR pistons should fit on LS rods since almost ever B series part is interchangable. The only thing Im not to sure about is whether on the LS the rod is the pressed or floating part, because on the ITR the wrist pin floats in the piston and the rod holds it in, but I believe(not sure) that on the LS the wrist pin floats on the rod and is pressed into the piston. If all this is true then the wrist pin will slide out and **** your block. Something to check into anyways.
Old Apr 10, 2003 | 08:50 AM
LODOSS's Avatar
Default Re: vtec pistons in b18b engine? (95 integra)
LS rods with any piston is fine
GSR/TYPE R rods cannot be used in a LS block unless some parts on the side is shaved off. but yes they can still work but needs to be taken to a machine shop. it is easier if you just stick the pistons on LS rods.
i got b16a PR3 pistons on my LS rods in a b18a block and it runs great.
Old Apr 10, 2003 | 08:51 AM
LODOSS's Avatar
Default Re: vtec pistons in b18b engine? (LODOSS)
oh another guy in Richmond =P your not a ricer send me a message and i can hook you up with good people to do work for ya. and it's always nice to know another person from the baords cause usually they are non-rice hehe
Old Apr 10, 2003 | 09:06 AM
ye ai double checked with my friend now , it was ls rods and USDM type R pistons. in his b18a
Charlie Moua's Avatar
Well with ctr pistions you'll end up with a high compression Doch no-vtec (12.4 i think)
ITR psitons will yeild a little bit lower compression. be prepared to get denation if your not running 96+octane. I would not reccomend this for a daily driver.
goog luck HTH
Old Apr 10, 2003 | 09:09 AM
DOHCon15s's Avatar
Yeah i need help with this **** becuase I'm gonna be runing all motor sleeper ls so I'm trying to raise the compression but I have no idea what the hell to do with making these pistons work.
Old Apr 10, 2003 | 09:21 AM
the pistons will just drop in , detonation is not ness true all the time . the ctr ones will yield higher comp i think ,
my JDM itrs will yield i think 10.6-11.1 in an LS block . so it wont be anyworries.
worst case scenario youll be the same compression as a JDM Type R or USDm type R
Old Apr 10, 2003 | 09:24 AM
heres a good help for b series pistons , check this out
http://www.geocities.com/Motor...s.htm
Old Apr 10, 2003 | 09:42 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LODOSS &raquo;</TD></TR><TR><TD CLASS="quote">oh another guy in Richmond =P your not a ricer send me a message and i can hook you up with good people to do work for ya. and it's always nice to know another person from the baords cause usually they are non-rice hehe</TD></TR></TABLE>
yea daniel isn't a ricer . It seems like pretty much everyone in richmond is though
Old Apr 10, 2003 | 01:40 PM
GSRacer1's Avatar
what does vtec have to do with pistons?
vtec is all about the head and yes they will fit you may have to put the ls rods again but they will fit and increase your c/r points (they will make your compression rate higher)
Old Apr 10, 2003 | 02:56 PM
Default Re: vtec pistons in b18b engine? (GSRacer1)
beucase too long of rods wont clear the head.
Old Apr 11, 2003 | 06:16 AM
DOHCon15s's Avatar
hey how much will you sell me those pistons for?
and what would i have to change internally to have my car run normal with a higher compression.
Old Apr 11, 2003 | 06:46 AM
JeremyL's Avatar
well first off the fuel you run...93 Octane minimum
Nisif
20
May 13, 2008 03:10 AM
730_Si
Oct 31, 2005 05:51 PM
Em0ne
Aug 20, 2005 11:01 AM
lscoupe
May 18, 2005 02:20 PM
DOHCon15s
Apr 11, 2003 05:43 AM
