What problems can a map sensor cause?
My car hasn't been acting right. I was having a problem with the idle and a backfirers. I went and changed the timing belt, had the valves adjusted, changed the fuel filter, and the primary 02 sensor. Any ideas? Could the map sensor cause these problems?
Re: What problems can a map sensor cause? (ramz7887)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 »</TD></TR><TR><TD CLASS="quote">My car hasn't been acting right. I was having a problem with the idle and a backfirers. I went and changed the timing belt, had the valves adjusted, changed the fuel filter, and the primary 02 sensor. Any ideas? Could the map sensor cause these problems?</TD></TR></TABLE>
is your check engine light on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 »</TD></TR><TR><TD CLASS="quote">i don't know where i can get a good ecu?</TD></TR></TABLE>
Try to borrow one off of someone with the same car as you (a friend, a family member, a fellow Ht member, etc.) A MAP sensor can cause your car to run like crap, but most likely it will throw a CEL before it does.
In my 91 Civic w/ ZC my car was idling like **** & would random;y stall for about a week & I couldn't figure it out. Then one day while cruising on the highway at about 70 the car died & threw a CEL for teh MAP sensor. I found a used one for $20 & viola problem solved. So, the point to this is: the MAP sensor can affect the car's performance w/o a CEL being triggered.
Re: What problems can a map sensor cause? (DJ_SaNdOz)
my car is over fueling whenever it wants.. i think it might be the map sensor? sound like something it would make it do? i have a mini me turbo with the hack.. thanks
Re: What problems can a map sensor cause? (turbod16y7vtec)
There might be irregular voltage going to the MAP sensor. I had this problem and had an idle surge from 500-900. It ended up being the ECU. Now she holds steady at 700.
hatchinprogress
11-23-2004 08:21 PM
