Hydrolock help
Old 11-03-2009, 05:56 AM
Masfino's Avatar
Default Hydrolock help
Soo my little hatchy ran thru no exaggeration a 2foot puddle at about 30mph and seems to be hydrolocked . The car does start however the check engine light comes on and it makes a terrible sound, doesnt sound normal. Its still drivable but at times sounds like it struggles so I havent been driving it since it happened. People have told me to let it sit in place untill it dries up and **** but idk dont seem to be working. Anyone got any idea on the possibilities of it being recoverable without having to swap ? And if taking it to a mechanic , would it get fixed if possible , quickly ?
Old 11-03-2009, 06:28 AM
Top Ramen's Avatar
Default Re: Hydrolock help
Originally Posted by Masfino
... it makes a terrible sound...
You probably have a bent rod or bent valve.
Old 11-03-2009, 06:33 AM
Masfino's Avatar
thats something that can be fixed fairly easy correct ?
Old 11-03-2009, 06:37 AM
Top Ramen's Avatar
You would need to tear down (disassemble) the motor and send it to a machine shop.
Old 11-03-2009, 06:39 AM
riceburner700's Avatar
its gonna cost some money to get fixed might be cheaper to find a replacement motor on craigslist or somewhere local to u
Old 11-03-2009, 06:54 AM
Masfino's Avatar
yea i figured swapping was going to end up being whats best for me
Old 11-03-2009, 08:41 AM
all-mtr-teg's Avatar
Kick whomever told you this in the head. How is water thats in a pretty much seal container going to dry up?
You need to change the oil and spark plugs and if that doesn't help, do a compression test and leakdown test to diagnose further problems.
Old 11-03-2009, 10:59 AM
95JDMEG9's Avatar
what he said ^
Old 11-03-2009, 05:34 PM
Masfino's Avatar
^^ haha i love yall for that lmao . Tomorrow im going to have it checked out hopefully its nothing serious
Old 11-03-2009, 08:48 PM
I say to change plugs as well cause the same exact thing happened to my buddy. His car sucked up water, my buddy immediately turned off the car, had it towed home then pulled the oil pan to make sure no bent rods. No bent rods, so he did a leakdown test to check for bent valves, no bent valves. So he put fresh oil in and the car started up, but stumbled and ran like crap. I came over, changed the plugs, and the car ran like it never sucked up any water
Cold Air Intake without bypass valve FTL.
Old 11-04-2009, 06:10 AM
Masfino's Avatar
^ yea my car starts up, the **** even drives still but REALLY rough and sounds bad. today imma go find out whats wrong with her.
Old 11-04-2009, 06:40 AM
Top Ramen's Avatar
I agree with the advice to change all of the fluids out completely (its worth a try) but be prepared for the worse. Also, pull all of the plugs and turn the motor over a couple of times before you start it again.
Old 11-04-2009, 07:24 AM
Masfino's Avatar
Whats everyones thoughts on driving it even under these conditions? I plan on getting a tune up today and seeing how it goes as well
Old 11-04-2009, 08:10 AM
DO NOT DRIVE IT OR START IT unless you know for sure you don't have bent rod(s) or valve(s)
Old 11-04-2009, 10:32 AM
Masfino's Avatar
mechanic told me it looks like its something simple , the spark plugs
Old 11-04-2009, 12:07 PM
I say to change plugs as well cause the same exact thing happened to my buddy. I came over, changed the plugs, and the car ran like it never sucked up any water
Old 11-04-2009, 12:25 PM
Fresh'86's Avatar
you mentioned you got a CEL...did you check what code you were throwing?
Old 11-09-2009, 10:05 PM
siblue_gzer's Avatar
http://hondamarketplace.com/showthread.php?t=2629060
Old 11-10-2009, 07:58 AM
Originally Posted by siblue_gzer
Kharma
Old 11-10-2009, 10:16 AM
Kharma
LOL!
deewaynex757
12
03-15-2012 01:46 PM
jkalex05
08-06-2009 10:09 AM
hondaVTEC09
06-20-2007 11:34 PM
EM1VtecSi
27
07-14-2005 03:31 PM
brent_G
06-14-2002 11:28 PM
Quick Reply: Hydrolock help
