h23 vtec with mahle golds + stage 3 cams?
Old 09-03-2011, 08:59 AM
4thgenphil's Avatar
Default h23 vtec with mahle golds + stage 3 cams?
hi all, i know i'm new so please be kind.
right i have a few spare h22's in the garage and a h23 so i thought i'd do the obvious and try to make a h23 vtec.
my basic budget build plans are as follows
pnp'd h22a head with flat face valves (got)
crower stage 3 cams (long story)
h23 balanced crack (got unbalanced)
h23 rods (got)
h23 block with oil squirtes and all that jazz (mainly because the bores are sooo clean) (got)
no balancing shafts (fiddling with it currently)
arp bolts where needed
h23 manual tensioner
ITBs
probably tuned on an aem ems perhaps with COP
now my question is could i use mahle gold 11.5-1s? i know the compression will already be high if i use h22a 10.6-2 pistons on h22a7 11-1.
the reason i am thinking of using mahles is due to seeing a couple of h23vtecs on here that blew type S/pde pistons.
my main concern is the valves hitting the pistons with the cams i will be using.
and another one, can i just balance the crank on its own?
i know in an ideal world i would sleeve the block but there isnt that many places in the uk who are willing to touch frm liners, those who are usually deal with porkers so will charge the earth
i will be using the car (mighty 4th gen jdm prelude) for a bit of drag racing but mainly for circuit track days
not really chasing figures but it would be nice to see some fairly decent ones!
i dont mind critism as long as its productive
also if any one can point me in the right direction so i can find info for my self that would be much appriciated
cheers
phil
Old 09-03-2011, 09:39 AM
SL0WEGG's Avatar
Default Re: h23 vtec with mahle golds + stage 3 cams?
The mahle's can be used, but you need to check your clearances and everything needs to be spot on.
rohec04
07-15-2006 10:34 PM
myh22a
08-17-2005 03:56 AM
Silude95
09-18-2004 01:48 PM
92lSilude
10-24-2003 12:57 PM
MiddSchoolRacr
08-07-2003 02:18 AM
Quick Reply: h23 vtec with mahle golds + stage 3 cams?
