gsr internals in ls block???
Old 03-09-2009, 10:08 PM
theme's Avatar
Default gsr internals in ls block???
is it possibly to bolt in a gsr crank rods and pistons into a ls b18b1 block? I dont wanna go vtec as i have a ls top end that I like. Just wanna know if this will work simply cause I bought a crank aluminum rods and forged pistons for what i was told was a ls but they are for a gsr.. anyway, thanks people..
Old 03-09-2009, 10:26 PM
92cxturbo's Avatar
Default Re: gsr internals in ls block???
yes it works but your losing displacement, and compression will be slightly more
Old 03-09-2009, 10:43 PM
95skunkedgsr's Avatar
wat brand pistons, rods ,and crank and wat comp i might be intereasted in buying it off u
Old 03-10-2009, 06:12 AM
theme's Avatar
stock knifedged crank, aluminum rods dont know the brand and cp pistons
Old 03-10-2009, 06:14 AM
theme's Avatar
Im not sure how i'd lose displacement?? a gsr is a 1.8ltr, after i got this and found out i was like ok this will rev better if it'll work... I have a professionally ported ls head with crower valvetrain and crower 404s, so i wanna stick with a ls block plus I dont wanna change blocks incase I ever drive the car to cali etc I want the numbers to match.
Old 03-10-2009, 06:32 AM
dyingwish's Avatar
The stroke is different between the GSR and the LS...less stroke = less displacement.
Old 03-10-2009, 06:37 AM
hmoobhero's Avatar
gsr crankshaft has a shorter stroke than ls crankshaft. thats why ls has alil more torque than gsr. are your piston stock bore size? also, the gsr rods are alil longer than the ls rods so there mite be some piston/valve clearance issue. do some research, theres a thread that talked bout this. gl.
Old 03-10-2009, 08:12 AM
b20c's Avatar
u can do it ls crank, rods in a gsr/r is a 2mm stroker setup. So it would be a
de-stroked ls might b ok wit 404s. i dunno
Old 03-10-2009, 09:22 PM
what comp pistons .. any intreast in sellin ??
Old 03-11-2009, 10:03 AM
theme's Avatar
maybe, there 9.7:1-10.2:1 I dont know why they advertise different compression for them but they what the part number comes back as. I think it depends on what head is the only thing I can think of..
Old 03-11-2009, 04:14 PM
o0 na i was lookin for the 11.5 12.1 range
Old 03-11-2009, 05:06 PM
theme's Avatar
its cool, i was gonna spray a staged big shot.. I paid 500 for it all in perfect shape..
1991islsv
11-21-2008 07:25 PM
Project_EK
06-05-2008 09:17 PM
patrick4588
10-18-2007 12:33 PM
tnsxsear1
02-08-2004 09:59 PM
B18C1_T
11-19-2002 01:20 PM
Quick Reply: gsr internals in ls block???
