f23a1/f22 head
Old 12-21-2014, 10:08 AM
thevtecnician's Avatar
Default f23a1/f22 head
Just wanted to share my setup
-f2b setup in crx
-F23a1 block
-F22a head gone over, mild port polishing
-k20a2 86.5 shelf pistons (unmodified)
-delta 272 dialed in
-custom tri y 2.5" header
-70mm port matched tb
-ported h23a1 intake manifold no butterflies, stock I.M. gasket (main runners untouched)
-balancer shafts left in, no belts
-shaved crank pulley
-custom 3" intake
-e85 fuel
Tuned on dynojet.
Old 12-21-2014, 09:22 PM
kingofbattle909's Avatar
Default Re: f23a1/f22 head
Thanks for sharing this
I'd like to take a gander at that header.
Is this a plateless H2B?
Old 12-22-2014, 04:19 AM
PyroProblem's Avatar
Nice to see something different. Always thought a Mildly built F series would be a fun budget friendly build. What kinda compression does it have with those pistons?
Old 12-22-2014, 05:16 AM
I'm running the qsd kit with a custom driver side mount bracket.
Compression is12.3:1 according to the calculator I used, but the head has been resurfaced an unknown amount.
I wasn't aiming for peak power with this header, but midrange for the street
Old 12-22-2014, 05:28 AM
RTFM
v4lu3s's Avatar
Very impressive engine. I was trying to talk a friend into a similar setup, glad to see my expectations exceeded in power output.
Old 12-22-2014, 06:11 AM
Thanks!
Original plan was bisimoto stage 2 cam and aftermarket intake Mani. Ran out of budget, but I know it would have broken the 200 mark. Also, most manifolds wouldn't clear my hood
Old 01-01-2015, 07:40 PM
ivan93egreppin210's Avatar
same setup as yours and roughly about the same power
https://honda-tech.com/hybrid-engine-swaps-18/f23-long-block-k20-pistons-delta-272-grind-3000109/
Old 01-02-2015, 06:50 PM
Anti-GDD White Knight Simp
TracerAcer2.2L's Avatar
Got mad respect for this, there's just something about n/a SOHC builds that just clicks in me.
Silly question, but what exhaust bolts are those?
Old 01-02-2015, 06:52 PM
Thanx bud. They are made by a company called J2
I've read that thread. You were revving to 7k too right?
Old 01-18-2015, 09:23 AM
Sepulveda87's Avatar
Any update on this beast?
Is your block bore still 86mm?
Old 01-18-2015, 05:46 PM
Bore is 86.5. Lotsa info up top in the original post. Nothing new really other than adding an oil catch can, and baffling the valve cover.
Finally drove it today though. Itr LSD and drag radials but still gets a bit squirly in second. No traction in first. I bet after an alignment and better suspension 2nd will grab hard.
Old 01-19-2015, 02:30 PM
so you bored it .5 over to fit the 86.5 pistons?
Old 01-19-2015, 02:31 PM
Yes I did
Old 01-20-2015, 03:12 AM
who made that header for you? Looks great. You need to get you a skunk2 h22 i.m man and some RDX injectors
Old 01-25-2015, 05:09 AM
Me and a coworker made the headera and I already have 550cc gtr injectors.
Planning to make these changes before next race season:
-skunk2 I.m. with adapter plate
-bisi valve train
-bisi level 3 cam
-higher redline (8000)
ALSO debating on trying out the obx itb's. Same cost roughly as the s2 Mani and adapter plate
Old 01-25-2015, 04:32 PM
Adapter plate...are you going to be using the Ultra Street or Race manifold? If so, I doubt the OBX would make the power the Skunk mani would make, unless you got a plenum for the ITB's. maybe then
Old 01-25-2015, 04:37 PM
I was referring to the original style skunk2 Mani for the h22. I don't think the new style has been released yet for the h22
Old 01-25-2015, 04:50 PM
slowsleeper's Avatar
Solid results Derek!
Old 01-25-2015, 06:31 PM
You're right, they don't have an ultra series for the H22...
But since you said you needed an adapter plate, hey you might as well make it for the B or K series Ultra Series mani!
Old 01-25-2015, 06:38 PM
F to k adapters exist, but the b series runners don't matchup. The spacing is a lot closer. I technically could try a k series ultra though
Old 01-25-2015, 06:42 PM
Yeah, don't know what I was thinking including the B series mani. Man I need to start charging for my ideas
In my mind, Pro Series<OBX<Ultra Series
Old 01-26-2015, 09:06 AM
Honestly if I did run a k series Mani it would be an rrc. But they expensive lol. Not really worried about hood clearance anymore so I'll most likely run the old skunk2
Old 01-26-2015, 09:33 AM
-bisi valve train
-bisi level 3 cam
I bought my adapter plate for the H22 i.m from swap shop racing.com
It comes with Hondata thermal intake mani gasket and the hardware. paid 275 i think shipped. The spacer is a lil thick so make sure that you have enough room for that and the i.m. Clearance made it difficult to install with out removing the head. i have maybe less than a inch from my firewall. I hope you have stiff motor mounts lol. that thing will bang on the wall if you dont. lol
Old 01-26-2015, 03:39 PM
That's where I plan to get mine from.
Do you have an accord? I got plenty of clearance. Here's the h23:
Old 01-26-2015, 03:51 PM
chrisnick's Avatar
Gut those runners/chop them down a bit! Here's a recent post from CB7tuner:
Originally Posted by jdm92_accorn
we started today at 10am and just finished about 8pm
first off old rockers vs new
non ported vs ported ( 8888 to 0000 ) f22a6 runners and f22b dohc plenum
stock 62mm s2000 throttle body vs bored and tapered JDM H23A vtec throttle body 70>64mm
my custom web regrind vs bisimoto level 2
what i started with and what we finished with all testin was done with the shop closed up and exhaust venting out through exhaust hoses to keep the climate as controlled as possible. humidity was a steady 34-36% and ambient temp was in the 64-66deg F range. elevation is 33ft above sea level.
the rocker comparison was 3hrs apart, intake manifold comparison was 28mins apart, throttle body comparison was 2-3mins apart, and camshafts were about 5hrs apart, had a boo boo and dropped a bolt down the in the timing cover, lol.
the peak numbers are impressive but the real fun is the across the board power. at 3500rpm there is about 20wtq gain, on average its a 13wtq gain and 14wtq peak gain. the largest whp gain of 17whp is at 5200rpm and peak for peak is about 13whp. 163whp/152wtq before and 176whp/166wtq after. no tuning was done until the camshaft was changed.
just for giggles F22A6 end results vs the last F23A non vtec combo. its funny how from 3600-3700rpm they make about the same power, lol. it must be a bad harmonic rpm for the intake or header.
im done for a little while till all my bottom end parts are here:tu:
Solid results though. Care to share any measurements on that header?(tube diameters/lengths)
Quick Reply: f23a1/f22 head
