can we get a official b16 all motor dyno thread
#102
Re: can we get a official b16 all motor dyno thread
B16A block
EK9 pistons (standard 81mm bore)
B16A head (3-angle valve seat cut, no porting or polishing)
NGK BKR7 copper spark plugs
EK9 cams and valve springs
Toda cam gears
JDM ITR (DC2R) airbox with K&N airfilter
JDM ITR (DC2R) throttle body (bored to 63mm) and intake manifold
HKS 4-2-1 manifold, stock JDM EK4 cat, JDM ITR (DC2R) B-piping and rear muffler
Over 215,000km on the clock.
JDM ITR (DC2R) gearbox with 4.785 final drive and LSD
Spoon 4.2kg flywheel
Walbro 255lb fuel pump
Unichip piggyback
198bhp @ 8000rpm, 179Nm (132lb ft) @ 6372rpm
Toda cam gears
Unichip piggyback
#103
ok i have a b16 and stock it has 160hp son all these guys put all this stuff on them and only showing like a 9 10 hp gain there not doing the right stuff or something
#104
I got a b16
Block
Stroker kit
13:1 compression pistons
Stock bore
Head
Drp stage 5
Web stage 2 cams
Skunk man.
68mm tb
750cc injetors
Its goin to be tuned on aem and no #'s yet but will be getin them soon n will post them up the shop I go to is thinkin around 230
Block
Stroker kit
Stock bore
Head
Drp stage 5
Web stage 2 cams
Skunk man.
68mm tb
750cc injetors
#105
Location: living too close to Karl, everythings busted, nc
#107
#108
sup guys,im about to put some blox stage 1 cams into my b16 and was wondering what kind of gains will it get,the motor is really healthy no oil burning or knocks,i also purchased some itr dual valves and retainers.
current mods on my b16a3.
aem cai
itr replica header
2.50 piping and a stock type s muffler.
i think that the muffler is gonna hold me back some and ill probably remove it when i get tuned.
aem cai
itr replica header
#110
99si b16a2 stock block/head
ctr header
aem short ram (aem v2 CAI in my car)
2.5 custom exhaust (apexi ws2 with test pipe in my car)
exedy stage 1 clutch and flywheel
bought the motor from a friend and when he had it in his car its dyno read 156.7whp/113.8wtq. That baby ripped in my 93 cx until the day it was stolen
ctr header
#112
Got the old b16a retuned on Saturday at IMW.
Basic setup
.25over PCTs
BC3+
Valvejob
Marcell's ported p30 intake
Edelbrock header w/ 2.5 collector
2.5 exhaust w/ cat
Everything else is stock b16.
tune by D-rob on BRE
Made 167/116 @Mcnews 2.5 years ago without the ported intake.
185/136
Thanks to D-rob for the tune and Marcell for the manifold
Basic setup
.25over PCTs
BC3+
Valvejob
2.5 exhaust w/ cat
185/136
#113
#116
Stock internal B16 all bolt-ons
First run couple months a go.... 152.97whp 105.71wtrq
Full PMR Intake system
Skunk2 Pro series Intake Manifold
Stock Exhaust Manifold
Stock Cat.
2.5" 5zegin catback exhaust
Vtec set at 5800rpm, any earlier there was a dip
NO TUNE
Second run couple hours a go.....166.26whp 114.78wtrq
K&N Filter (RF1014)
Blox Velocity Stack
PMR Intake tube
Skunk2 Proseries Intake Manifold
Vibrant 4-2-1 J-Spec Header with true 2.5" collecter
Vibrant 2.5" Hi-flo Cat
Skunk2 Megapower R 70mm (2.75") Catback exhaust
Vtec set at 5600, could probably pull in back a bit more
NO TUNE
So pretty much with the full exhaust still no tune I gained 14whp and 9wtrq, also youll notice I was able to bring vtec back a bit earlier and its hit harder now
My air/fuels are way out of wack when vtec hit, tuner said the way it is with a good tune Id be in the mid-hi 170whp
Stock Cat.
NO TUNE
K&N Filter (RF1014)
Blox Velocity Stack
PMR Intake tube
NO TUNE
#118
from YEARS ago:
- DC 4-2-1 header
- craptastic intake tube
- FPR
- chipped ecu
- craptastic exhaust system
basically, craptastic.
- DC 4-2-1 header
- FPR
- chipped ecu
#119
really nice good to see their is other b16 lover out their too.
this is goin to be my set up:
b16a stock bore block hot tanked and honed
b17 crank & rods
P30 pistons
1 layer head gasket
gsr head p&p
skunk2 valve springs and retainers
skunk2 stange2 cams
flat valves
profecional products intake manifold
65 mm tb
type r header
2 1/2 in. catback
h22 injectors
obd 1 p28 chrome chiped
on 97 pump octane
lsd sir trany
exedy stage 1 clutch & pp
light flywheel
any one know about how much whp will i get and can i actualy do it on 97 pump gas my elevation is 745 thanks and any recomendations will help.
b17 crank & rods
P30 pistons
1 layer head gasket
gsr head p&p
skunk2 stange2 cams
flat valves
65 mm tb
type r header
2 1/2 in. catback
h22 injectors
on 97 pump octane
lsd sir trany
light flywheel
#120
i have 2000 JDM b16b engine (came from 2000 ctr with around 5k miles on it) with 2000 JDM B16B CIvic Type R Tranny with Spoon 1.5 way LSD, fujita short ram intake, stage 2 exedy clutch and exedy lightweight flywheel, no cat - straight pipe, cleaned injectors, new 10w-30 oil change, new 3 quarts of Motul synthetic clutch type tranny oil , Stock header, IM, ecu, always put 91 octane only, others are stock. But I cant find my proof dyno sheet. SH*T! I just remember 213whp and 127 wtrq. This was Sept of last year. But I'll try to find the dyno sheet so i can post it here.
#121
#122
#123
#124
loving this thread. i have an 00 si with a b16. i have been working on it for a while. it has:
port polished head
ctr cams
type r header
type r intake manifold
type r throttle body
aem intake
straight pipe
exhaust
ngk spark plugs
unorthodox aftermarket lightweight pulley set
running a little higher compression
b&m fuel pressure regulator
stage one clutch and light flywheel
jdm p30 ecu
im going to tune it with hondata s300j. i hope i gain a lot. any ideas of what my numbers will be?
port polished head
ctr cams
type r header
aem intake
straight pipe
exhaust
ngk spark plugs
jdm p30 ecu
#125
