Can a 96 gsr tb work on the old school sk2 intake manifold
Old 03-19-2019, 11:32 AM
purposebuilt's Avatar
Default Can a 96 gsr tb work on the old school sk2 intake manifold
Hi I was woundering if I can use a tb off a 96 gst snail intake manifold and put it onto a old school type r style sk2 manifold or do I have to get a b16 or ls or aftermarket tb.
Old 03-19-2019, 03:56 PM
Moderator
TheShodan's Avatar
Default Re: Can a 96 gsr tb work on the old school sk2 intake manifold
Originally Posted by purposebuilt
Hi I was woundering if I can use a tb off a 96 gs-r intake manifold and put it onto a old school type r style sk2 manifold or do I have to get a b16 or ls or aftermarket tb.
is this what you mean? If so? Then yes it can fit on a 1st gen skunk2 intake manifold
Old 03-22-2019, 06:15 AM
aw614's Avatar
The only issue I might see with the GSR TB is the throttle body plate that holds the cable.
Old 03-22-2019, 06:23 AM
Moderator
TheShodan's Avatar
Yep. He'd need a B16 or Type R bracket assembly.
Old 03-26-2019, 10:38 AM
So all I would need is the throttle cable bracket and it will work
Old 03-26-2019, 09:57 PM
JRCivic1's Avatar
Nope. The throttle wheel on the GSR T/B pulls in the opposite direction as a B16A, LS or ITR style throttle wheel does, therefore, you would also need the GSR throttle cable and the cable bracket that mounts to the T/B itself. For a complete OE install, you would also need the firewall mounted cable stay bracket.
aeros
03-07-2011 11:35 AM
Boriqua0555
02-25-2007 04:34 PM
SSBlueDC2
08-03-2004 10:54 PM
canuck-mx6
02-23-2002 12:03 PM
905_S2K
09-12-2001 05:09 PM
Quick Reply: Can a 96 gsr tb work on the old school sk2 intake manifold
