B20v cam test, pro1's vs ddtech's
Old 05-03-2014, 05:16 PM
Spawne32's Avatar
Default B20v cam test, pro1's vs ddtech's
Test done @ Driven Performance in NC
Tuning/Install done by Darius
Setup is a budget built B20vtec, Nothing crazy, standard run of the mill shelf setup, 84x89 mild compression, 114 race gas, TypeR head, victorX manifold
Most people know that Darius’ dyno does read a tad low, the generally math is around 16-20whp less then most other dynojets in the area.
The cams werent swapped same day. Customer Original made 217whp pro1’s, Swapped in a set of DDTECH’s and picked up a huge gain. The pro1’s were dropping off rather quickly after 8500ish, On the dyno, they didn’t rev the DDTECH’s as high, Seems like they’d made a few ponies more on the peak then the pro1’s but from 5-8 they really shined up. Gains of over 25+whp in some areas over the pro1’s.
Pro1’s were degreed, DDTECH’s weren’t, they were dropped in with Derek’s Drop in settings.
Sharing the results, I know Derek is hesitating sharing any results because people think he has some “underlying" agenda, but I feel like progression should be shared, regardless most of the people who know him follow him on Facebook, his website and/or his DDTECH facebook page and they see the results already, but for people who don’t follow, this is one of many recent dyno results.
Old 05-03-2014, 06:21 PM
Onyxeros's Avatar
Default Re: B20v cam test, pro1's vs ddtech's
That part of the graph looks good, can we see the whole run?
Old 05-03-2014, 07:53 PM
DDTECH's Avatar
That is the whole run, 3-9ish..
The car is a strict track car, with some "minor" daily driving, I believe.. Anything under 5K doesn't matter on this car really, You're seeing the entire thing, AFR's were the same, My cams took a tad less timing I believe vs the pro1's. Also required less clearance I believe as well. Pro1's were a great cam for the guy, he ran some super awesome times despite is ultra low dyno numbers, he just wanted to go bigger.. These are pretty close to my Stage 2 shelf profiles I have out.
Old 05-03-2014, 08:55 PM
d15Beta's Avatar
i think he meant the whole dyno sheet picture with rpm at the bottom (a/f reading if possible) and from the start of the pull 3k to redline
like how you see a good dyno sheet...
nonetheless.. we saw pro1's decline at around 8200rpm too much the same as wat spawne has mentioned FTW!
Old 05-03-2014, 09:27 PM
93egSLEEPER's Avatar
That is one stingy *** dyno. Jesus lol. Thanks for the test results. I'll keep eyeballing his cams, and when I finally get to the point of "more" I'll pull the trigger. Keep up the work Derek. Also, I still have some "measuring sticks" if you're still interested.
Old 05-04-2014, 05:01 AM
DDTECH's Avatar
I can get that, no problem.
Old 05-04-2014, 05:36 AM
blackeg's Avatar
wow i didnt know they peaked so early. thats barely more rpm than something like a ctr cam peaks. not good for having a nice long powerband
Old 05-04-2014, 07:14 AM
Runnerdown's Avatar
As long as the owner or car remains anonymous why not share more setup info. What header, injectors etc. I think the reason people get bent out of shape is when there is a lack of any details or tech and just "brand X vs Y"
Old 05-04-2014, 07:23 AM
d15Beta's Avatar
it really would depend on alot of things...
but a pro1 is a decent cam... but u gotta keep in mind ... a 2liter is a 2liter...
so even with mild compression... that "demand" on the induction and exhaust is there...
it would prolly peak higher on a b18c or something...
on a b16a it can pull to 9.5k LOL
Old 05-04-2014, 08:16 AM
Onyxeros's Avatar
Yes, thanks
Just a standard dyno sheet. HP/TQ rpm etc.
Old 05-07-2014, 03:05 PM
DDTECH's Avatar
Sorry, Had to wait for the tuner to get a few to overlay. Anymore questions, Just ask, be happy to answer.
Old 05-07-2014, 07:29 PM
Twenty47's Avatar
Both graphs need some work
Old 05-07-2014, 08:02 PM
I serve phở for my babies
ohsnapzafingcu's Avatar
Results would be more accurate if the AFRs were smoother.. Jesus. How much extra power is left on the table for both sets of cams? Judging by how bad the graphs look I bet there's a better tuner that can extract a lot more out of each cam
Old 05-07-2014, 09:55 PM
d15Beta's Avatar
yeah now its a comparison with data on both cams
Old 05-08-2014, 05:41 AM
dankeg's Avatar
the afr doesnt match....
Old 05-08-2014, 06:49 AM
h2.4's Avatar
Afr, let alone ignition tuning. I know you can't run same ignition timing on both cams, but as long as both timing tables were optimized for both cams..... But thats what makes it a little difficult to make A-B comparisons. Because its not just A and B that we're comparing. I've retuned cars and came up with improvements and graphs that are more dramatic than this comparison, with no changes other than retuning the car. I'm not saying either cam isn't working better than the other, but that pro1 tune looks a lil weak, I'm pretty sure you can smooth out that crater in the upper rpm where the comparison of biggest hp difference is.
Old 05-08-2014, 06:52 AM
DDTECH's Avatar
From my understanding, pull on the pro1's done, then cams dropped in, and tuned, thats it, I do KNOW they were making a race that weekend, so its possible that the powerband that matter was tuned, nothing more. In any case, I assume Rob wanted to just share results of something that was done, this was done a month or so back, the car has since gone to the track and is running MUCH faster times both et / trap then he was with the pro1's, he's having issues with axles now, where as he never had issues before..power is coming on much stronger and faster and i think he's trying to learn how to redrive the car so to speak.
Built2Race
169
06-20-2011 05:52 AM
Pandahatch
37
10-02-2005 06:01 PM
pr0honda
36
05-12-2005 10:13 AM
I Like Boost
10-21-2002 10:56 PM
Quick Reply: B20v cam test, pro1's vs ddtech's
