B20B/P8R parts suggestions for B20b's high compression build
Old 09-03-2017, 10:05 PM
B20b.'s Avatar
Default B20B/P8R parts suggestions for B20b's high compression build
i have a b20b with a p8r head not thinking about going vtech because already have the p8r
ctr high compression 84mm piston
arp rod bolts
skunk 2 stage 2 cams(any suggestions?)do I have to upgrade my springs and retainers?
370 injectors with upgraded fuel rail and fuel pump
Is the itr water pump any different from the gsr?
would it be around 170whp with a tune
i just want to see everyone's suggestions (any other upgrades I should do?)
B20b. is offline
Old 09-04-2017, 04:52 PM
JRCivic1's Avatar
Default re: B20B/P8R parts suggestions for B20b's high compression build
Yes, you do have to change valve springs and retainers. ITR and GSR water pump is the same part number. It is not necessary to change to a VTEC water pump... it will spin slower with the larger pulley and will not add any additional cooling volume over your stock LS water pump. It should make your number with a quality tune... assuming you have a quality header and exhaust system.
JRCivic1 is offline
Old 09-05-2017, 08:25 AM
solorex's Avatar
Default Re: B20B/P8R parts suggestions for B20b's high compression build
You'll want a short ratio tranny for sure. Other than that, I ran a 170hp B20z (just stock head) with Crower 403 cams for years and it's a great torquey reliable engine.
solorex is offline
Old 09-05-2017, 08:39 AM
k20z1ej1's Avatar
bro. this is literally the 5th thread you have made asking the same exact question about using the same parts and people keep telling you the same thing. seriously, what is wrong with you.
k20z1ej1 is offline
Old 09-05-2017, 08:50 AM
k20z1ej1's Avatar
https://honda-tech.com/forums/all-mo...block-3303360/
https://honda-tech.com/forums/all-mo...-b20b-3303434/
https://honda-tech.com/forums/honda-.../#post51352004
Theres another one that the mods deleted. These 3 + that one + this one makes 5 threads about p8r head, b20b block, rc 370cc injectors etc.
k20z1ej1 is offline
Old 09-05-2017, 03:31 PM
JRCivic1's Avatar
This OP has only 1 post... are you suggesting that the OP is creating multiple user names to ask the same questions ???
JRCivic1 is offline
Old 09-05-2017, 03:33 PM
k20z1ej1's Avatar
Yes. Dc2 Richard and b20b. The mods deleted the last thread that b20b posted. They are all the exactly same. P8r head, b20b block, rc370 injectors, same exact questions.
k20z1ej1 is offline
ef-you
08-06-2004 06:17 AM
GapxGuy
13
06-26-2003 08:50 PM
h46it
03-25-2002 07:53 PM
Quick Reply: B20B/P8R parts suggestions for B20b's high compression build
