b20 vtec build need to do research
I have bought a b20 block and a b18c5 head with no cams, springs and needs new valves. I was wondering if anyone can give me some info on the build. Also what cams are good and intakes also. I have a lot of questions about the build
Re: b20 vtec build need to do research
have you done any actual research? this is not how to go about it. if you're expecting to be spoon fed this information, this is not the site for you.
here you go bud:
http://lmgtfy.com/?q=how+to+properly+build+a+b20+vtec |
Check out the how to build a reliable b20v/Lsv thread I has a lot of info.
Google is ur friend use it
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
this thread help me out a lot on my build I hope it dose the same for you |
Thanks for the links it has sent me in the right direction I do have a question still tho will the stock sleeves be a problem
Should b fine. Depending how much power u want. U want more power then bore it out. 82mm is the max to bore, more than that then I recommend aftermarket sleeves.
Okay well I've googled it and haven't found anything on it but what are your inputs on locking in vtec
Originally Posted by Eg.ls.turbo
(Post 49059752)
Originally Posted by Uncle Dave
(Post 49064196)
I think you got your numbers wrong a B20 is 84mm bore STD.
You obviously don't know who Uncle Dave is^
Your replies give me headaches :ugh: |
(Post 49064979)
Yes a b20 is 84mm but the sleeves are weak depending how much power he wants to push, he won't b pushing much power with thin sleeves. I was just sayin since he hasn't mention how much power he wants out of it, that 82mm with 350-400whp is the limit for dd, better b a damn good ass tuner to hold up those sleeves. B20 sleeves are thin and like the max I would go on them are 300-350whp depending on a good ass tune. But I don't know how much power a b20 sleeves can hold. Just my opinion for a dd
(Post 49064979)
(Post 49065552)
Ok let me get this straight you want him to put 82mm pistons in a 84mm bore correct ? and how is a N/A b20 going to make 350 to 400whp?
And if u read my last couple sentence I said I didn't know how much horsepower a stock b20 sleeves holds. SORRY gUYS I FOrGoT THIS WAS A b20V lOl. I had mind on b18. Sorry again guys. |
Posted by clean rice :You obviously don't know who Uncle Dave is^
Your replies give me headaches No I don't I'm still learning the ropes as I go too but I do like to be corrected when I'm wrong. It's not like in trying to give bad info I'm tryin to help to the op with some knowledge I know. Since u posted here y don't u give the op some knowledge |
Either you're 12 years old, or you are from a different country. Which is it?
I've given plenty of "advice" over these past 10 years on here...thanks. |
(Post 49065672)
No I didn't say that. I was say on a b18 motor 82mm bore would b the max to bore out. I didn't say anything about 82mm pistons in a b20 block.
And if u read my last couple sentence I said I didn't know how much horsepower a stock b20 sleeves holds. SORRY gUYS I FOrGoT THIS WAS A b20V lOl. I had mind on b18. Sorry again guys. Now Clean Rice is one of technical people on here and you really need to listen to what he says as he has been around for a very long time on here and has a very good knowledge base with Honda's. |
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/p-r-e-stock-sleeve-b20vtec-dyno-3164743/ 2 year old engine hmm B20 sleeves are just fine when they are built and tuned CORRECTLY
Originally Posted by clean rice
(Post 49066160)
(Post 49059752)
