B16 vs b18 pros cons anything else (im new here please dont hate)
Old 07-08-2013, 06:11 PM
Carkid95's Avatar
Default B16 vs b18 pros cons anything else (im new here please dont hate)
Hi im new here but i was just wondering the differences and pros and cons and anything else with the b16 and b18. I know 1.6 and 1.8 litre but most after that is kinda (insert fart noise). Please dont hate or anything im new and just tryna find stuff out.
Thanks.
Old 07-08-2013, 06:13 PM
RESIDENT
TypeRfit's Avatar
Default Re: B16 vs b18 pros cons anything else (im new here please dont hate)
http://en.wikipedia.org/wiki/Honda_B_engine
Have a good read with this. It will break down the B series engine pretty well.
Old 07-08-2013, 06:20 PM
DDTECH's Avatar
What are you looking to achieve?
First thing I'll tell you, no replacement, for displacement.. when staying NA.
Old 07-08-2013, 06:36 PM
nealnanoHX's Avatar
1.8L>1.6L. More power and tq. My B18B1 motor stomped B16's no problem.
Old 07-08-2013, 06:42 PM
Runnerdown's Avatar
Yep, right on.
I still like the B16a, but its really just outdated. Not much to offer for NA anymore. Great budget foundation for a turbo street car @ 3-400, high hp but not quite enough torque to create the wheelspin issues with bigger cranks, 2.0 liters etc. Also makes a good power plant for a lightweight road race weekend warrior.
Old 07-08-2013, 06:52 PM
Uncle Dave's Avatar
B16's you really need to spend alot on gearing to get them to perform,b18's and b20's are just torquey and gearing is not as much of an issue.
Old 07-08-2013, 07:06 PM
Carkid95's Avatar
I was thinking about a stripped out eg hatch but didnt know if b16 or b18 would be best. 100% wanna stay all motor but im not looking for a million horse power, maybe 200? Or a little less?
Carkid95's Avatar
Wanna keep the cost down as well. If possible
Old 07-09-2013, 04:57 AM
nealnanoHX's Avatar
Go Ls Vtec or B20 Vtec. It will cost you a lot more $ to get a 1.6L to 200whp.
Old 07-09-2013, 05:21 AM
a.k.a. Komodo
Kozy.'s Avatar
Ultimately, a B16 can be built to produce the same power as a B18.
It will cost more and be less relaxing to drive though as it'll be revving much higher.
Old 07-09-2013, 05:53 AM
Carkid95's Avatar
Cost estimation on lsvtec? Or is just if i get lucky and find something cheap
Old 07-09-2013, 06:02 AM
Carkid95's Avatar
And will it bolt right up and plug right in? I just swaped the motor and trans in my toyota mr2 it bolted right up but the wiring was hell.
Old 07-09-2013, 06:42 AM
redyute's Avatar
In the process of a lsvtec build right now for my 99 ek, b18b1 short block pulled from the pick and pull,i kept the rods and went with oem b16 pistons acl main and rod bearings and thrust washer,b16 head stock rebuild still at the machine shop,em1 harness with ecu, 99 gsr stock cams,blox intake manifold, 97 gsr tranny.I still need to get exhaust system two mounts and front axles.I would say money wise i have around $1350.00 in it right now.Now this is a reliability build and not a high hp build just need a good daily driver.Another thing to consider is i did all the assembly and did not have to pay anyone to do it so that saved me some money.Hope this gives you an idea of ball park figure but not every build is the same.
Old 07-09-2013, 04:54 PM
Carkid95's Avatar
Couldnt i buy an eg hatch shell and an integra and swap the motor into the hatch with a vtec head and put a b20z with vtec head in the teggy? Am i way off or? Im new to honda but im trying my best sorry
Old 07-10-2013, 05:05 AM
nealnanoHX's Avatar
But it will never have the tq of a larger motor. Tq is what gets you moving and wins races.
Old 07-10-2013, 05:09 AM
nealnanoHX's Avatar
A basic Ls Vtec done right with a stock B18B or B20 bottom end will cost you around $1500-2000 with everything you need block, Vtec head, rebuilding the head, IHE, trans, swap parts, tuning. If you want to put some P30 pistons in the motor then it will run a little more.
Old 07-10-2013, 05:12 AM
a.k.a. Komodo
Kozy.'s Avatar
Seriously? Are you really going to start that one?
Power wins races. You have a gearbox for torque.
Old 07-10-2013, 07:08 AM
jimmysxxl's Avatar
^that.
Engine Torque can be modified. With an Infinite Gearbox Torque would have zero value.
Old 07-10-2013, 07:53 PM
B_Swapped93's Avatar
Since on a budget i'd say a GSR(b18c1) but I think OP want's LSV...either way a properly built LSV or GSR can see 200whp(or just under) with a stock block bolt on's+cams and a good tune and you should be able to hit that mark if the engine is healthy.
Old 07-11-2013, 05:11 AM
nealnanoHX's Avatar
It would be pretty hard to hit 200whp with P72 or PR4 pistons, I am going to try to get as close as possible though . You would need to swap to some P30 or P73 pistons and run a good cam to get to 200whp.
Old 07-15-2013, 04:04 PM
Toddsdx's Avatar
I am looking into the same thing. I have basically settled on a b18c1 because its a sexy all around engine. But im gonna turbo mine too. The only question im having is, is there another engine in the series that will react better to a boost?
Old 07-15-2013, 04:30 PM
RevRipe's Avatar
I am just gonna point something out. The phrase "I was thinking" ain't gonna get you far on this board. I seen a lot of people talk about building this and that but it never actually happens. I'm not saying thinking is a bad thing but less talk and more action. Try to be specific if you got a question about something and rather than being so general. You gonna get a whole lot better answers if you follow me...
eg8ynot
10-04-2008 05:41 AM
squeezedeghatch
12-26-2006 07:43 PM
Curbow_USMC
08-10-2005 08:06 AM
d spamony
19
03-17-2004 10:08 PM
turbohf
05-10-2002 01:52 PM
Quick Reply: B16 vs b18 pros cons anything else (im new here please dont hate)
