Allmotor worked S2000 Endyn head (NHRA World Record holding)
#126
Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote"> How did you arrive at 15.5-1? What were the head cc's, block cc's, and gasket cc's?
This is not the best formula. But it is close.
Required VE= (9411x BHPx BSFC ) / (disp.x RPM). There is more to it. But this is OK.
Modified by DonF at 5:23 PM 10/19/2008</TD></TR></TABLE>
forgot the detail one by one,
but the total head chamber cc + gasket volume cc - piston top (dome) cc = 37.9cc
bore 86 x stroke 95 the displacement was 551cc each (2200cc)
CR -- > = (551/37.9) + 1 = 15.55 : 1 CR
Ok, Don Thanks a lot for the VE formulla..
BTW, how is the limit of Dynamic CR for racing fuel such as C16....
btw anybody ever try Elf powerboost?? C16 out of stock in here, wanna try the ELF but affraid of knocking...
Modified by jt-sport at 3:32 AM 10/23/2008
#127
Re: (ENDYN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDYN »</TD></TR><TR><TD CLASS="quote">The engine has been plagued with broken aluminum rods for the last two seasons. We took control of the engine building this year and designed (very long) lightweight steel rods for it. The engine saw months of development on our dyno, and the program was wildly successful...with one exception. Regardless of modification to the dyno, we were never able to run the engine over 11,500 rpm (where power was still climbing). We are having a gearbox built for the dyno that will reduce the rpm the brake will see so we can continue our development work.
As of today, the engine is in the car, and it's scheduled to make a shake-down run Sunday.
....and yes, with 17-1CR, and rules-mandated slow-burning C16 fuel, the engine carded many pulls with VE's ranging from 135-137% from 8000rpm up. </TD></TR></TABLE>
How did the shake down run go on Sunday?
#128
The Old One
Re: (SMSP)
They told me that they made a single aborted run at 8.62 at 155. The track was so slick that the car was sideways most of the run, however, the report also said that the engine pulled to 11,800 effortlessly. They plan to try again this coming weekend, track conditions permitting. No broken rods for once, which is aso good.
#129
Sorry, a lil bit OOT...
since there was a lot of maestro (Don, Combustion Contraption, ENDYN, Greg Cheetah, etc) in here that talking about things that related to thermal efficiency..
so i want to ask about something about it
it was about a system that using Dry Ice vapor that sucked into motor.. (i dont know what it called, but i've seen a guy using it on their V8 Hotrod motor and offroad motor)
i know that cold temperature from the Dry Ice could reduce the air intake temperatur and it increasing performance, since a cold air was having a lot mass on its density... increasing VE a bit
but how about the CO2 contain that Dry Ice got? i think it hurting the combustion efficiency....
and how is the effect on internal motor? since there was extreme rapid temperature change whenever the motor combusted on its normal temperatur and then suddenly a very cold vapor goes into the combustion chamber??
will it destroy the internal things inside the combustion chamber??
any detail info or "how to" about this system??? im interesting about this, and plan to use this thing on my motor if i could have a more information that support about this system..
Thank U..
Thank U..
#130
Re: (ENDYN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ENDYN »</TD></TR><TR><TD CLASS="quote">They told me that they made a single aborted run at 8.62 at 155. The track was so slick that the car was sideways most of the run, however, the report also said that the engine pulled to 11,800 effortlessly. They plan to try again this coming weekend, track conditions permitting. No broken rods for once, which is aso good. </TD></TR></TABLE>
congrats Larry :shakehand:
#131
#132
Re: (Justin Jones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Jones »</TD></TR><TR><TD CLASS="quote">New S2K head work section on the Endyn site:
http://www.theoldone.com/compo...0.htm</TD></TR></TABLE>
Stuff looks nice but tell Larry he should have at least used a new water tube on that IM. Looks like he took it off an old EF that was sitting out in a field in Canada.
#133
Re: (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">
an old EF that was sitting out in a field in Canada.</TD></TR></TABLE>
Ouch! As opposed to a field somehwere in Northern Michigan?
Modified by Jaker at 10:45 AM 10/29/2008
#134
Re: (Jaker)
It's called thermal cycling. Read somewhere Rolls-Royce used to bury the engine blocks in the field and let it cycle through hot and cold seasons to "season/stress relieve" da blocks.
Rolls-Royce fo da win!!!
#135
Re: (-LoL-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -LoL-eg6 »</TD></TR><TR><TD CLASS="quote">
i want one in my dc2
#136
Re: (Master of the Universe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Master of the Universe »</TD></TR><TR><TD CLASS="quote">It's called thermal cycling. Read somewhere Rolls-Royce used to bury the engine blocks in the field and let it cycle through hot and cold seasons to "season/stress relieve" da blocks.
Rolls-Royce fo da win!!!</TD></TR></TABLE>
I'd rather take a pig buried in the ground with coals for the day in Maui.
#137
Re: (SMSP)
I'd rather take a pig buried in the ground with coals for the day in Maui. </TD></TR></TABLE>
now that makes me want a 'lechon with sum homemade gravy
#139
The Old One
Re: (Aquafina)
If the engine's displacement (89mm x 84mm) was increased, we'd have to add more weight to the car, which would affect performance adversely.
#140
Re: (SMSP)
umm, reminds me of my trip to OAHU,
Pig was freaken bomb!!
Modified by b20vtech at 4:35 PM 10/31/2008
#141
Re: (b20vtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">
Modified by b20vtech at 4:35 PM 10/31/2008</TD></TR></TABLE>
Got to wait a couple more years for the kids to get a little older and we'll be back. On the road to Hana.
#143
Re: (diesel32)
the 8.12 ET wasn't fast enough to "Backup" the 7.996 ET Record
but the 7.996 ET was fast enough for the 8.12 ET Record at that time
NHRA wrote it Officially down as a Record at 7.996 ET on NHRA Site
then later notified Del the Official had made a mistake
and the Record was put back to 8.120 ET from 7.996 ET
about a Month later or so Del went 8.05 ET which at the time was
good enough to reset the Record
and the other run was fast enough to backup the 8.05 ET,
but Del decided not to reset it...i forgot exactly the reason why,
but ask Del .
the Head was originally ported by Del
then i re-Ported it and picked up the Flow Numbers quite a bit
and changed up the velocity FPS Profile in the Head.
When Del went 7.996 , 8.120 Record F/D, and the 8.05 ET
was with the Head Ported by Meaux Racing Heads (myself )
#144
Re: (MaxRaceSoftware)
Larry Widmer ( Endyn ) is now working with Del
and has Ported Del a new Cyl-Head, maybe even 1 or 2 more by now ?
Del's had his Engine at Endyn and on Endyn's Dyno .
Del said Larry's a super great extremely knowledable Engine Builder / Head Porter
and Larry and Del are working together to get back the F/D Record soon !
The Dragster's been plagued for quite awhile by many weird electrical/mechanical
problems...but it shouldn't take them long to solve all of them !
#146
Re: (Aquafina)
What about the 14,000rpm you were previously hoping to acheive? So far it looks like the highest is 11,800. IRL only rev to 10,300. How much higher are their springs good for?
GRPNHRD
02-28-2008 09:52 PM
