2.25" Exhaust on B16 with Tuner 3's
Bought a Del Sol with a rebuilt but stock B16 which supposedly has S2 Tuner 3's installed on a semi-built head. She pulls hard after VTEC up to 9k - more than I'm used to "feeling" so they might be T3's afterall but I'm not planning on pulling the cams to find out.
Anyway, the car's exhaust (header, straight thru to Magnaflow muffler) is too loud so I was planning on throwing in a resonator and noticed the tubing is 2.25" which may or may not be too restrictive? Since I was thinking of "eventually" modding the engine for AM, I thought of installing a 2.5" mandrel kit from VRS along with a high-flow resonator and a Vibrant muffler. Or should I just throw on a regular no name $20 2.25" resonator (not high flow of course) for now to get rid of the loud tone? |
Re: 2.25" Exhaust on B16 with Tuner 3's
go 3'' it will be ok if you use big resonators.
Dude, it's an all-motor B16!
with stage 3 cams go for a 2,5"
Originally Posted by 7rrivera7
(Post 45534427)
(Post 45529508)
(Post 45534427)
You're allowing the motor to breath easier, it'll make the power. |
Can a car lose HP from going from exhaust to straight header (infinite, way bigger than 3")?
Originally Posted by OMG
(Post 45537969)
Originally Posted by ALL M0T0R
(Post 45536824)
3''. Its been proven and its been well discussed. The less backpressure the better.
What about putting a device at the end of the header that gradually slows down the exhaust to avoid turbulent flow and also create a reflective negative back-pressure wave to create a tuned cancellation of exhaust-valve reversion? That might be better than a straight transition into said "proven" Monster 3" exhaust.
Everything after the final merge collector is either for emissions or evacuation, and is a restriction.
Just trying to help, search, its been discussed and debated until people are blue in the face. The noise is about the only draw back to running a bigger pipe diameter. Could careless about "street" credit. |
Stuff some fiberglass(or maybe some argyl socks) in your exhaust.
Restriction = power |
Taken to its logical conclusion, no header works best.
Go for a 2.5,
in my case i'm runing a stock b16 block stock head, itr cams, itr intake mani/TB w/ cai chiped ecu and 2' ex.. stock ex header
but i have a 2.75 ex here at home.. 2.75 will make more power than 2'? |
Originally Posted by flavio
(Post 45544826)
next week i do the feedback :D
(Post 45544071)
People that think back pressure is a myth are missing some understanding of the physic behind fluid dynamics...Some people will also tell you that the second butterflies in the gsr intake manifold is bad because it is restrictive! The word restrictive is probably the only word they can understand! The intake problem is quite a simplier problem, but still some people won't understand it. The exhaust air flow is alot more complex since the fluid dynamic behind it is completely different.
Some people really think that engineers working for bmw and other car company are stupid and that they put dual butterflies intake and variable exhaust muffler just because they want the engine to make less power...sigh...Anyway i could continue this text forever, but that would probably be useless! |
What about Exhaust scavenging? Don't pipes that are too large cause the exhaust to slow down and actually screw up flow?
Originally Posted by Ridewithme38
(Post 45882190)
Got some good people on here commenting. Thanks for all the feedback!
