***Official All-Motor Stock Sleeve B20VTEC Thread***
#2026
Re: ***Official All-Motor Stock Sleeve B20VTEC Thread***
236 whp, 169 tq Dynojet
84.5 x 89
12.5 Roller wave pistons
Endyn headwork
Crower 63402-2 cams
Skunk2 Ultra Street
Skunk2 70mm TB
Short ram intake w/filter
Plm toda header
3" skunk2 exhaust w/test pipe
370cc injectors
93 fuel
S300 v.2
4.7 ITR trans
Mikey @ PF Autoworks tuned (much thanks!)
84.5 x 89
Endyn headwork
Crower 63402-2 cams
Skunk2 Ultra Street
Skunk2 70mm TB
Plm toda header
370cc injectors
93 fuel
S300 v.2
4.7 ITR trans
Hey what is your cam gear setting? I'm thinking use these cams Crower Stage 2 in my B20 Vtec for use in road race
#2027
B20z
84.5x89
weisco 14-1 forged Pistons,
skunk 2 forged rods,
fully balanced bottom end,
b18 c6 type r head,
diy polished & ported head,
skunk 2 pro 3 cams, dialed in to spec,
skunk 2 pro series springs,
skunk 2 pro series retainers,
skunk 2 lma's
bosch 470cc injectors,
toda cam gears,
jenvey 48mm itb's,
skunk 2 megapower tri-y header,
3" exhaust.
car made 262bhp &173ft lbs torque
engine is in a classic mini and previously ran a 11.8 at 111.5mph and only had 230bhp at the time
84.5x89
b18 c6 type r head,
skunk 2 lma's
toda cam gears,
jenvey 48mm itb's,
3" exhaust.
#2028
Anybody with 1/4 mile track updates? My 2.0 is still sitting on the stand, hoping to get it running for the track this spring.
#2029
No Jodas
Figured I'd share my setup since I took so much inspiration from here. Basic rundown:
No 1/4 mile times worth gloating about... second hit at the track went 13.8 @ 101, spinning and throwing up oil all over the track due to my catch-can.
- 84.5x89 CSS bottom end, 11.5:1 wiseco pistons with eagle rods
- RLZ Engineering CNC ported head, unknown "version" with Supertech valvetrain
- Buddyclub Spec4 cams, degreed per the cam card with GE cam gears
- PLM SMSP replica header, test pipe, 60mm Tanabe Touring Medallion Exhaust
- VictorX Manifold, 70mm Ballade Sports TB, 3" intake with BLOX velocity stack + filter combo
- RDX 410cc injectors, Walbro 255lph fuel pump, 93oct from shell
- Tuned by Alex @ Granite State Dyno in NH on a DynoJet
#2030
#2032
I was kinda thinking your exhaust had something to do with it. I'm running Torco on top of 93. It's a fully built GSR head with S2 IM and S2 TB and BC4 like I said with full Omni Power VT.. ARP all thru it also. It's gonna spin 9-10k at Delacruz and I can almost guarantee 250 but the proof will come after of course. B16 trans, MFactory LSD, fidanza 7.5, single drive crank pulley, walbro 255, aem rail, rc440 injectors, big tube smsp rep ,PWJDM power chamber. Built to exceed 200 wheel definitely 220-230. It's about 13:1, 275-280 psi per cyl as of yesterday when I checked it
#2033
Do you have facebook? Hit me up I'd like to chat about our builds some more and this HT browser on my phone sucks ***.. Joseph Boivin
#2034
#2035
Update on my setup, tomorrow is dyno time at Delacruz Motorsport in Pelham NH. Ill post my results as soon as i get a chance. Was planning on running torco on top of the 93 but cant find any so it looks like its gonna be straight 93.
----Block and Trans:
84mm Stock sleeved B20B from HMOTORSONLINE
RS Machine ITR rep pistons
Stock rods with ARP bolts
ACL bearings
Fidanza 7.5 lb flywheel
VMS single pulley
ARP head studs
B16 transmission with LS 5th
MFactory LSD
GSR water pump
----Head and everything else:
GSR head port n polished
Buddy Club 4 cams
Omni Power Flat valves
Omni Power Dual springs
Omni Power Retainers
Blox LMA's
Skunk2 cam gears
Skunk2 Pro series intake manifold
Skunk2 70mm throttle body
Password:JDM Carbon power chamber
AEM fuel rail
RC 440 injectors
NGK 8 plugs
NGK blue wires
Walbro 255 pump
Hondata s300 V3
AEM wideband
Cusco catch tank off block port
SMSP rep big tube header
Skunk2 Megapower RR 3" no cat
Cometic head gasket
Hondata intake gasket
Golden Eagle conversion kit
Mishimoto full size radiator
Blox slim fan
Spoon SW388 16x7"
Falken RT615K 205/40R16
ACL bearings
VMS single pulley
ARP head studs
MFactory LSD
GSR water pump
Buddy Club 4 cams
Blox LMA's
Skunk2 cam gears
AEM fuel rail
RC 440 injectors
NGK 8 plugs
NGK blue wires
Walbro 255 pump
Hondata s300 V3
AEM wideband
Cometic head gasket
Blox slim fan
Spoon SW388 16x7"
#2036
Bigger exhaust would likely get you about +10WHP throughout the entire band. Very nice build though, I'm sure it's a blast to drive
#2037
ACL bearings
VMS single pulley
ARP head studs
MFactory LSD
GSR water pump
Buddy Club 4 cams
Blox LMA's
Skunk2 cam gears
AEM fuel rail
RC 440 injectors
NGK 8 plugs
NGK blue wires
Walbro 255 pump
Hondata s300 V3
AEM wideband
Cometic head gasket
Blox slim fan
Spoon SW388 16x7"
ACL bearings
VMS single pulley
ARP head studs
MFactory LSD
GSR water pump
Buddy Club 4 cams
Blox LMA's
Skunk2 cam gears
AEM fuel rail
RC 440 injectors
NGK 8 plugs
NGK blue wires
Walbro 255 pump
Hondata s300 V3
AEM wideband
Cometic head gasket
Blox slim fan
Spoon SW388 16x7"
#2038
JE Pistions, 84.5mm wide, 12.5:1 ratio
Egale H beam rods
Buddyclub racing cam with springs, retainers, adjustable cam gears
Cometic b20 - b16/b18 headgasket
stock b20 crank
stock bolts ons with a aftermarket fuel rail and regulator
tuned at 127kw with crome, fully stock internally before i pulled it apart to rebuild
hopping for 200kw/260hp
once built, it'll be a weekender and track car.
currently got a LSD with a solid center clutch.
will post again once its built and dynoed
Egale H beam rods
stock b20 crank
#2039
Question for the guys who rebuilds their blocks.say your block goes out.and you need a new one.would you pick a B20 block over the b18c if you can grab them for the same price?
#2040
Depends on the use, if not going to push it hard I like the extra b20 tq.
B18c has more value for sure. What are you paying?
#2041
Moderator
I like the modularity of the B18C1 over the B20. No need for a LSVTEC kit, and I can always use a B20/LS crankshaft to gain torque. It would be about 20lbs-ft less due to the slight smaller bore (3'm) but I'll take that modularity over the betting a B20 any day
#2042
Mostly street use.my car is acting up and someone says it needs a new block but i don’t think it does.but im wondering if he does come down to that.would it be better to slap on a vtec block that was suppose to be on there in the first place.mostly looking for reliability or go for b20?if I were to pick the b20 I’d want to upgrade the pistons to itr to make it atleast last.if the b18c then it’s staying stock.by the way they built this My b20 vtec motor doesn’t look like it’s lasting
#2043
anybody else with an opinion on this?
whats failing on your current b20?
#2044
Someone said my block is bad.im getting jerky and hesitating while im on the gas sound like a pebble rattling in a can.
also at idle in the video you can hear a metallic sound when I press the throttle.does that sound like cracked sleeves?
#2045
Moderator
https://youtu.be/b3i25f_i030
#2046
The jerking and hesitation and pebble ratting in a can noise when on the gas almost perfectly describes pinging and detonation which could cause you to crack your sleeves. You need to tune that out ASAP before you hurt it.
Mild cracked sleeve could look like a blown head gasket, I had a cracked sleeve that drove totally fine, mixed no fluids but overheated once in a while. If you’re unlucky you’ll grenade the block. Do a compression test first and if it’s okay fix your tune and just keep using what you have.
#2047
#2048
#2050
do you think I’m ok and just being paranoid? Just as a heads up this engine is in a Austin mini and has a lot less room around the engine.
