***Official All-Motor Stock Sleeve B20VTEC Thread***
Old 10-05-2014, 07:02 AM
  #1926
sixstroke's Avatar
Default re: ***Official All-Motor Stock Sleeve B20VTEC Thread***
Originally Posted by raverx3m
bro lol you know you thread jacked and you still do it like your explanation would somehow make everyone feel better that you taking this thread off topic and adding more unrelated posts.
make a build thread that's what they are for. and people will answer.
Figured it would serve the thread well and frankly, the time (and thread space) that you took up to call me out, could have been to answer my simple question.
Oh well.
Old 10-05-2014, 04:14 PM
  #1927
cksnah252's Avatar
Stock sleeves
85mm Wiseco K594m85 13.0:1+ pistons (played with the zeal calculator and it seems I have around 13.5 compression!)
Alaniz port and polish B16 head
Skunk2 Pro series manifold with 68mm throttle body port matched
Endyn Bumpstix
RMF replica headers 2.5
3" Kteller piping
RC 440 injectors
tuned on 93 octane
car made 229whp at 8500rpm and 167tq
Here is the video of me testing the car
Trying to look for the dyno sheet because I misplaced it!
Was thinking on upgrading to 4piston ultra street manifold, hondata coil packs, and running water meth injection because there isnt any e85 available in RI that I know of. What you guys think?
Old 10-06-2014, 09:03 AM
  #1928
felsonmiguelina's Avatar
Originally Posted by civic00sir.
What kind of injectors are you using if you don't mind me asking? nice build by the way.
I don't mind at all, I am using RC 310cc injectors
Old 10-06-2014, 12:42 PM
  #1929
hpmx18's Avatar
b18b block 86mm
wiseco custom pin height 86mm 16.5 compression piston
skunk2 ultra race manifold & q45 90mm throttlebody
b16 ported & polished flow test, full ferrea valve train , skunk2 pro 3 cams 55cc injectors
hytech big tube headers full 3in exhaust no muffler
on dyno break in made 162hp & 170tq reving to 5k rpm should b on dyno next week and see what she does and will b running E85 gas
Old 10-06-2014, 06:52 PM
  #1930
OMG
OMG's Avatar
Stock B20 block, Stock B16 head with VJ, e85, full exhaust, tuned on Crome
https://www.facebook.com/ProdigyRace...type=1&theater
Old 10-06-2014, 09:08 PM
  #1931
93egSLEEPER's Avatar
Originally Posted by hpmx18
b18b block 86mm
Not quite a "stock sleeve B20vtec" like the thread is asking for but sounds promising...
Old 10-06-2014, 09:11 PM
  #1932
You play coy so well... "stock block" but not internals
Old 10-07-2014, 05:21 AM
  #1933
jiggacivic's Avatar
Stock Port b16 head
Jun 3 Cams or i have a set of Pro1's from my turbo car i might try as well
Supertech valvetrain
skunk2 pro series intake manifold
70mm Throttle body
Modded RSX injectors
DC Sports 4-1 header
Stock Sleeve b20b
Stock b20 crank
Probe 84.5mm 12.5:1 Pistons
Scat Rods
ACL Bearings
No Block guard
B16a sir2 LSD transmisson
ACT HD Extreme Clutch Disk and Pressure Plate
Ectune for management
Planning to put a 50 or 75 shot of nos on it and see how much it will make.
Old 10-07-2014, 07:14 AM
  #1934
EscoSi's Avatar
B20Z block
Supertech 12.5:1 84mm pistons
Brian Crower Rods
Stock Crank
P&P ITR Head
Ported Skunk2 Pro Series Manifold
70MM TB
Skunk2 Springs & Retainers
Skunk2 Pro2 Cams
OEM ITR injectors
PLM Headers
2.5 Mandrel bent exhaust piping
Forza Exhaust
90 octane gas
Old 10-07-2014, 07:23 AM
  #1935
OMG
OMG's Avatar
nice tq, cold air intake?
Old 10-08-2014, 03:59 AM
  #1936
seelback's Avatar
Originally Posted by cksnah252
Stock sleeves
Endyn Bumpstix
3" Kteller piping
RC 440 injectors
tuned on 93 octane
B20vtec 0-100mph 230whp - YouTube
Anybody can correct me if im wrong but I think the 4piston S2 intake manifolds are specifically for their heads but im sure they will work fine on any head, with that being said I would pick one of their ultra streets up and try it out, COP is a good choice. Try looking for fuel depots in your area, public or private and se if you can get e85 or e98 but you'll need bigger injectors. Or try looking for any airports or little airstrips that sell 100LL AVGAS or 100 unleader AVGAS, AVGAS here in jacksonville fl is around 5.60 gallon and no need for bigger injectors. Fuel Depots may require you buy 55 gallon drums at a time.
Old 10-08-2014, 02:44 PM
  #1937
Stock sleeves
Endyn Bumpstix
3" Kteller piping
RC 440 injectors
tuned on 93 octane
I'd get "bigger" cams for starters. IMO those cams are leaving power on the table.
EDIT: I was thinking of different cams, ignore my comment here.
Old 10-09-2014, 11:49 AM
  #1938
I like to party
2LEM1's Avatar
I've seen those cams make over 290whp... I'm pretty sure the cams aren't holding him back.
I'd look at that header first.
Old 10-09-2014, 11:58 AM
  #1939
Header, intake and TB. I should erase my comment, I was thinking of different cams. #brainfart
Old 10-09-2014, 08:02 PM
  #1940
cksnah252's Avatar
Ok guys, sounds good!
I actually found e85 around me area and decided to pump like 4 gallons fill up.. The car runs lean now smh....
Old 10-10-2014, 03:58 AM
  #1941
seelback's Avatar
need tuning(even for daily driving, partial throttle)from 93 to e85. Going from e85 to e98 I needed and little tweaking on my car.
Old 10-10-2014, 05:29 AM
  #1942
cksnah252's Avatar
Ok i guess ill just burn off whatever I pumped ans fill it back up with 93 octane.. Thanks bro!
Old 10-10-2014, 05:45 AM
  #1943
cksnah252's Avatar
Alright ill keep that in mind next time! Thanks!
Old 10-16-2014, 09:09 PM
  #1944
ecko_3420's Avatar
Have you guys used oil cooler with a b20v? How did you do it?? Add another sandwich plate?
Old 10-17-2014, 06:37 AM
  #1945
prjct92eh2's Avatar
I haven't yet, but from my research i've read that is fine. I plan on running a mocal thermostatic on top of my golden eagle.
Old 10-25-2014, 06:23 PM
  #1946
cisco_kid's Avatar
Still working on it very slowly but coming together.. my expected power is around 185-190 with what i currently have and around 240 with future upgrades.
Currently:
B20 block bored to 85mm
Block guard
YCP ITR pistons (11.8cr at current altitude.. 12.5 sea level)
Stock rods
ACL RACE Bearings
ARP HEAD studs
KMS TYPE R billet Girdle
GSR head
Skunk2 Pro Manifold
ITR 62mm TB
CT Engineering Ice BOX with ITR 3" intake tube.
Comp clutch stage 1 clutch
COMP clutch 12lbs flywheel
GSR tranny with ITR LSD and Ls 5th gear.
JDM ITR Ecu
For now.. stock exhaust manifold and piping..
Future mods (shooting for 240+):
Port & polished head with port matched intake manifold (skunk ultra street)
Ferrea valvetrain
DD Tech Stg 2 Cams
Skunk2 pro cam gears
70mm TB
Toda SPEC HEADER
2.5 exhaust
440cc injectors for pump gas tune or 1000cc for e85 (if it comes more available in my area in the next year or 2)
Hondata tuning.
Old 11-15-2014, 05:56 PM
  #1947
43!
43!'s Avatar
236 whp, 169 tq Dynojet
84.5 x 89
12.5 Roller wave pistons
Endyn headwork
Crower 63402-2 cams
Skunk2 Ultra Street
Skunk2 70mm TB
Short ram intake w/filter
Plm toda header
3" skunk2 exhaust w/test pipe
370cc injectors
93 fuel
S300 v.2
4.7 ITR trans
Mikey @ PF Autoworks tuned (much thanks!)
Old 11-15-2014, 08:23 PM
  #1948
V-SPEC 1's Avatar
Originally Posted by 43!
http://imgur.com/Q5VB69o
84.5 x 89
Endyn headwork
Crower 63402-2 cams
Skunk2 Ultra Street
Skunk2 70mm TB
Plm toda header
370cc injectors
93 fuel
S300 v.2
4.7 ITR trans
Lower numbers were hot, the higher numbers on the fans
I'd like to hear the 3" skunk2 exhaust on this beast. Video would be nice
Old 11-17-2014, 10:12 AM
  #1949
43!
43!'s Avatar
I would be happy to when it warms up a bit. I will say it's stupid loud, obnoxious, and I love it.
Old 11-18-2014, 05:27 PM
  #1950
V-SPEC 1's Avatar
I have the same exhaust for my ek hatch but I haven't installed it yet waiting for more parts for the swap. It's megapower rr 76mm.
Quick Reply: ***Official All-Motor Stock Sleeve B20VTEC Thread***
