Acura TSX Acura TSX Sports Sedan. USDM TSX and Euro/UK/JDM Accord.
Some Basic TSX Questions
Old Jan 17, 2008 | 10:25 AM
fjt's Avatar
fjt
Default Some Basic TSX Questions
Is there a FAQ thread on the TSX? I want some info since i just recently bought one but i cant find any related topics.
I basically want to know how is the performance market for this car. How much power can a stock block handle. Is the TSX head the same as the Type R? Cams? How much can the Auto(Shiftronic) tranny handle?
etc...
I still havent decided what way i want to go in the future with this car in terms of performance.. Turbo/ SC/ All Motor
Old Jan 17, 2008 | 01:48 PM
evertp1's Avatar
JDM TypeR/USDM TypeS cams are interchangable... but the heads are totally different....
the Type S is mad to Rev high, like 9000RPM high... the TSX should not go past 8000RPM
but the head are interchangable
Now, the TypeS/R head has larger intake ports to allow for more volume of air at those high RPMS..., meanwhile the TSX has small intake ports compared to the RSX-S
P.S. there is a market for the TSX
Old Jan 17, 2008 | 03:00 PM
fjt's Avatar
fjt
So is it worth to do a Type R head swap or just to get the Type R cams?
Will Compression ratio change by changing to a Type R head?
Old Jan 20, 2008 | 01:23 AM
evertp1's Avatar
Default Re: (fjt)
you can change the compression ratio by installing a thinner head gasket. but if you are going to do all that work, you might as buy the TypeS head and throw it on...
comperssion ratio can only change by pistons and head gasket.... the head can lower the compression if its really sh*tty like cracked head or burnt valves.
if you want more power, do go through all that... do this:
-Hondata ECU relflash
-Injen MR Intake (stablizes AFR)
-headerback exhaust system
(this setup well give you atleast 200WHP according to hondata)
PLUS
add a thinner headgasket for higher compression, and port and polish the stock TSX head for better air flow, should be adding atleast 5+HP on top of 200
Old Jan 20, 2008 | 08:01 AM
fjt's Avatar
fjt
Thanks for the reply.
Ive been searching and it seems like Supercherges is the way to go for these cars..Atleast for now.
Would adding the Thermal Intake Mani Gasket help as well?(Honata or Hondata style)
I already have an INJEN Cai which came installed with the car when i bought it.
Old Jan 26, 2008 | 01:01 AM
yoshidade79's Avatar
Default Re: (evertp1)
yo i also recently purchased my 2008 tsx in september 2007. i just put the cold air intake on and planning to throw so headers and maybe a nice exaust! they have a couple of good mods for this car. blk on blk 6 speed navi ! jp lipkit.
Old Jan 26, 2008 | 01:07 AM
Default Re: Some Basic TSX Questions (fjt)
honestly, throw a small turbokit boosting between 6-10 pounds. wont have to mess with internals.
Old Jan 26, 2008 | 12:50 PM
evertp1's Avatar
Default Re: (yoshidade79)
i just bought a Injen MR CAI
BaseBoy
Sep 30, 2015 07:49 AM
angelSIR-G
Acura TSX
19
Mar 18, 2006 10:29 PM
cha chi
Nov 21, 2003 02:55 PM
DBallz
Apr 30, 2003 07:26 PM
