Maintenece Light...
Re: Maintenece Light... (NAturalDC2)
Is it not in the same place the Integras have it on the botton on the left of the steering column under the dash?
Re: Maintenece Light... (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi »</TD></TR><TR><TD CLASS="quote">Is it not in the same place the Integras have it on the botton on the left of the steering column under the dash?</TD></TR></TABLE>
They did it different this time. Can't remember exactly off the top of my head but it's in the manual.
Re: Maintenece Light... (tony4311)
Has something to do with the ODO button the clutch pedal and the Ignition.
I think the clutch needs to be in then turn the key to the acc position then hit the odo button
something like that
something like that
If u have an "owners manual" it will tell you there. I know having someone to tell you exactly what to do would be easier but life ain't fair.
I want to be MADE into Ice-T
Re: Maintenece Light... (poweredbyacuras)
Ok maintenence light, on the right of your gauge cluster there are 2 long buttons, slect and reset. use the arrows to scroll through the menu untill you see, "Oil life % " then push and hold the reset light for about 10 seconds untill the screen says, something about reseting the oil life %, keep holding the button. Then you will see a 3rd screen and simply let off the reset button for 1 second, then push again and the light should go off.
Just keep holing the reset button untill you see a screen that says "RESET MAINTENECE" then let off the button for 1 sec hold one more time for 2-5 sec. and the light will go off.
Re: Maintenece Light... (TABIAS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TABIAS »</TD></TR><TR><TD CLASS="quote">Ok maintenence light, on the right of your gauge cluster there are 2 long buttons, slect and reset. use the arrows to scroll through the menu untill you see, "Oil life % " then push and hold the reset light for about 10 seconds untill the screen says, something about reseting the oil life %, keep holding the button. Then you will see a 3rd screen and simply let off the reset button for 1 second, then push again and the light should go off.
Just keep holing the reset button untill you see a screen that says "RESET MAINTENECE" then let off the button for 1 sec hold one more time for 2-5 sec. and the light will go off. </TD></TR></TABLE>
OHyea the drivers door has to be shut and the key has to be "ON" not Running.
Oh yea, the drivers door has to be shut and the key has to be in the "ON" position, not Running.
fella's im sorry, i thought this was the TL fourm. On the TSX there is a **** on the left side of the cluster, simply push and hold that with the key in the ON posisiotn, and hold untill the light goes out. sorry for the wrong INFO above.
chatman_55
03-14-2008 02:54 PM
