DIY: COLD air intake.. similar to the COMPTECH one.
Location: hittin corners so hard you can taste my rims..
you need to start off with a K&N drop in, but if you've seen your thought about buying the comptech icebox, they give you a crappy foam filter, and a few of people on the Acura boards have been changing them out and putting in a K&N..
so whats so great about the COMPTECH kit? you get a new air box lid, a junk foam filter, and a 90 degree inlet tube.
so.. my plan was to just remove the resonator, and avoid all that bullshit.. but then i realized before the resonator, it had a "U" pipe, and it was the same size at the rubber boot hose going to the airbox.
so i cut it in half with a hacksaw.. and its basically the same thing as the COMPTECH one..
SO WHY NOT SAVE YOUR 150 BUCKS..
also.. i dremel'ed off the back of the grille insert to allow air flow 100% non-restrictive. ALSO, SO YOU CAN SEE MY AWSOME CIA INTAKE TUBE!
Re: (Curiouz_G)
actually i went to vegas this past weekend, and with the weird weather going on in LA right now, i ran through flash floods on the way back.
some serious down fall.. couldn't see ****, and my MPH was about 20. didnt' doubt the K for a second.
Re: (Built B16A)
Hmm I would also be worried about hydrolocking But I do know this saves money but would you reccomend doing this over buying the Comptech Icebox or my fav the Injen CAI. I live in New Orleans and Im sure you guys know what flooding can do here eg: Katrina. How far down to the bumper do these CAI's go and would you reccomend the Air bypass? Thanks appreciate any help.
well.. i drove 15 miles through a flash flood.. **** was crazy comming back from Vegas.. and i was towing my jet ski also.. so i have full faith in my DIY CIA.
yes.. i have a hitch on my 06.. lol
Re: (Built B16A)
You could also do like this:
Use exisitng parts and pieces from OEM intake
I have the Comptech lid and the above set-up
Modified by IntegraGSR23 at 4:32 PM 9/13/2006
Johnny Gasparini
06-15-2007 11:42 AM
pat.ter.rick
08-27-2005 11:12 PM
Rexxy
01-23-2002 09:33 PM
