How to remove Acceleration pedal (EP3)
Help: How to remove Acceleration pedal (EP3)???
I'm trying to install the Mugen pedals , I can't seem to remove the acceleration pedal. Help?
Modified by JDM_DC2_2001 at 9:44 AM 5/23/2008
Re: Help: How to remove Acceleration pedal (EP3)??? (JDM_DC2_2001)
It's probably just like the DC5, slide the throttle cable out from the top of the pedal, there should be a slot where you can slide it out from, then there's two nuts that hold it onto two studs that are coming out of the firewall, it's pretty easy to remove.
Re: (thetunersource)
I bought some vibrant aluminum pedals for my EP3 and it looked like there was a roll pin maybe holding it in. Really hard to see. A punch would knock it out. I left that one stock so the other two are aluminum but that one is stock. Works for me. But if I spent the money on Mugens I'd probably want them all on there too.
Re: (square_1)
Did you not see my post? I just looked it up in the EP3 service manual, it's the same as the DC5, you just slide the cable off the top of the throttle pedal. Might have to lift it towards you a little bit then slide it to the right then remove the two nuts which hold the pedal against the firewall and it comes right out.
Shouldn't take you more then 5 minutes.
92SiHatchie
16
11-02-2018 02:56 PM
ewing
08-19-2014 10:00 PM
MonkeyPuzzle
01-25-2006 12:09 PM
