how do I remove cables from the e-brake?
Old Nov 11, 2004 | 08:44 PM
CrazyModGSR's Avatar
Default how do I remove cables from the e-brake?
I got a new e-brake handle assembly for my '94 Integra, since the one I have now is crapped out. Anyway, wondering how I remove the two cables from the part of the e-brake assembly circled in the picture below. Thanks
Old Nov 11, 2004 | 10:21 PM
xprohx's Avatar
I think too much
Default Re: how do I remove cables from the e-brake? (CrazyModGSR)
<-- Also curious.
Old Nov 12, 2004 | 12:07 AM
LSvtec03's Avatar
Default Re: how do I remove cables from the e-brake? (xprohx)
release the ebrake and loosen the adjusting bolt until it comes off. then tug one cable to the side and it will slide up and out the slit. do the same for the other cable. next its just a couple 10 or 12mm bolts holding the ebrake to the floor. install is the reverse of the removal.
hope that makes sense; it should once you're looking at what im talking about. i'll see if the helms has a step by step.
Old Nov 27, 2004 | 10:57 PM
Default Re: how do I remove cables from the e-brake? (LSvtec03)
i unbolted the whole assembly and tried to tug the cables up and to the side and in every direction and still won't budge. what a pain. any other recommendations?
B_Swapped93
Jan 15, 2014 07:46 PM
imadigitalgod
Sep 2, 2010 10:08 AM
the_dxB16
Mar 8, 2009 08:36 AM
E.
Mar 27, 2008 08:20 PM
EKcivichatch
Suspension & Brakes
Apr 28, 2006 07:03 PM
