how to solve this crappy problem
Old Jun 17, 2010 | 09:32 AM
vtectouge's Avatar
Default how to solve this crappy problem
i drive civic sedan eg8, today my stereo died along with my car clock, why does this happen? i think its the fuse burned im i right? if not please do tell me cuz its bloody bored to death with the silent in my ride..
and my rear right door cant be open from inside and outside ...dohh why this silly things happens to me?? how should i fix this? do i have to remove the door handle from outside? im blurred now
Old Jun 17, 2010 | 07:26 PM
vtectouge's Avatar
Default Re: how to solve this crappy problem
come on guys give me something...
Old Jun 18, 2010 | 03:13 AM
vtectouge's Avatar
bump
Old Jun 18, 2010 | 03:44 AM
95DC2GS-R's Avatar
the fuse that blew is probably the radio-cig lighter fuse or the back up fuse
Old Jun 21, 2010 | 06:44 AM
ken9's Avatar
I think the door handles can be remove from the inside by taking off the door panel. FOr the h/u you might want to check all wire under the dash and fuses for burn..
Old Jun 21, 2010 | 06:38 PM
fcm's Avatar
fcm
Old Fart
It is the "back-up" fuse in the engine bay fuse box, probably a 7.5A, it blows if you have an aftermarket HU with the HU 12V constant, [yellow] wired to the stock 12V constant in the radio harness.
You will need to run a fuse 12ga lead from the batt. to behind the HU, connect the HUs yellow lead to it, don't forget to cap off the stock 12V constant and replace the fuse, with the proper one, NEVER replace a fuse with a bigger one, you can burn your car to the ground. 94
Old Jun 23, 2010 | 05:48 PM
redline75's Avatar
i had this same issue with an integra i bought from a friend they previous owner before him installed the head-unit with out any type of wire connectors when i pulled it to see why the head-unit didn't work only a couple of the wires had tape on them.
i never knew about this fuse i had checked all the inside ones with no luck was going to just bite the bullet and replace both the clock and the hu
square_1
Oct 29, 2010 10:36 PM
CheddarPopcorn
Jun 25, 2009 10:35 AM
alperin
Oct 29, 2007 06:40 PM
97civicB18C
Audio / Security / Video
28
Oct 8, 2006 01:39 PM
