WIXvsFRAM OIL FILTER COMPARISON
Old 12-06-2005, 07:38 AM
Renegade's Avatar
Default WIXvsFRAM OIL FILTER COMPARISON
This applies to Integras as well as Civics, I was not sure where to post this so I put i in the ITR since it was going in an ITR.
Here are some pictures to compare filter sizes between the FRAM and WIX( large and small) oil filters.
Doing a search online said that the comparable replacement to the honda filter and the Fram PH3593A in WIX filters would be PN 51334, the smaller version of that WIX would be PN 51356.
Below are the images comparing sizes between the 3 filters.
WIX 51334 is slightly larger than FRAM, but the 51356 is much smaller then the FRAM and WIX 51356.
For those of you who are wondering why a large to small filter and vice versa. The theory is that a smaller filter would raise the oil pressure and in return yielding better VTEC activation, *shrugs shoulders*, the other side of the argument is a larger filter will give more area which will help lower the oil temperature.
I have not checked oil pressures or temperatures. Just bought the filters and thought I would share.
In my opinion, if you want to lower the oil temperature, i would suggest and oil cooler, or an oil filter relocation kit.
Either way I thought I'd share the pictures
Old 12-06-2005, 08:12 AM
Madspeed's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (Renegade)
interesting comparison....
Old 12-06-2005, 08:22 AM
Larkin W.'s Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (Madspeed)
hmmm. Interesting.
I personally am an S2k Filter guy nowadays.
-Larkin
Old 12-06-2005, 08:24 AM
Dave_B's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (Larkin W.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Larkin W. &raquo;</TD></TR><TR><TD CLASS="quote">hmmm. Interesting.
-Larkin</TD></TR></TABLE>
Same here, can't go wrong with OEM parts.
Old 12-06-2005, 08:29 AM
98 Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Larkin W. &raquo;</TD></TR><TR><TD CLASS="quote">I personally am an S2k Filter guy nowadays.
Old 12-06-2005, 08:40 AM
Renegade's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (98 Spec R)
S2k filter is smaller?
how much is usually?
thanks
Old 12-06-2005, 08:50 AM
Haleiwa-Brando's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Renegade &raquo;</TD></TR><TR><TD CLASS="quote">For those of you who are wondering why a large to small filter and vice versa. The theory is that a smaller filter would raise the oil pressure and in return yielding better VTEC activation, *shrugs shoulders*, the other side of the argument is a larger filter will give more area which will help lower the oil temperature.
I have not checked oil pressures or temperatures. Just bought the filters and thought I would share. </TD></TR></TABLE>
Also this is why SPOON, JUN, TODA....all the big Honda race guys and dumb little me use an S2000 Honda filter with a metal hose clamp tightened around the middle. This prevents any possibility of swelling.
Try that with your new filter.
Old 12-06-2005, 09:16 AM
KOALA YUMMIES's Avatar
I've been using the Mobil 1 filters for the longest time, the same size as the original Honda filter they used to sell before all this mini filter and S2k stuff. But then again I also still use the Mobil 1 5w30
Old 12-06-2005, 09:34 AM
98DC2-ITR's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (KOALA YUMMIES)
Guys FWIW here @ Import Auto Salvage we will not use nor do we recommend our customers used FRAM oil filters. I am not bashing them but 8 out of 10 core engines we receive back have FRAM oil filters installed. We have cut several of them open to discover that they have collapsed internally leading to oil starvation. I know that FRAM is a readily available brand but I refuse to believe that this is the only reason we get so many core engines with them installed. On numerous; and I mean numerous occasions; we have sold B series VTEC engine swaps (USDM and JDM) to have the customer call us with a problem with VTEC. 9 out of 10 is a problem with VTEC not engaging. We inquire about wiring etc etc and determine everything is in order there. We then ask what brand oil filter they are using. Again 9 out of 10 say they are running a FRAM. As hard as this is to believe ( I have witnessed this in person several times ) upon changing from a FRAM to another brand the problem instantly was cured. I know this is hard to believe but trust me it is true many many times over. I will not use nor do i recommend anyone use a FRAM oil filter on anything they drive. Subaru actually sent out a service bulletin several years back and stated not to use a FRAM on their engines either. I personally use a Purolator (sp) filter and have never had any problems. Heck I just changed my oil an hour ago with no issues. I am not saying that all FRAM filters are junk I am just saying that I would not recommend them to my fellow ITR owners... We are a dying breed as it is so lets not loose any more C5's to oil starvation...
Old 12-06-2005, 09:38 AM
Collector-o-Guns and Drinker
Splat's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (98DC2-ITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98DC2-ITR &raquo;</TD></TR><TR><TD CLASS="quote">Guys FWIW here @ Import Auto Salvage we will not use nor do we recommend our customers used FRAM oil filters.</TD></TR></TABLE>
I'll use Fram filters in my Scout, but that's about it. Of course, that filter is damn near the size of my head, so even if the innards start collapsing, it probably won't impede flow.
WIX are highly-rated filters, but I'd still use OEM if I still had a Hype R. Hell, even my old Volvos get Mann (OE supplier to Volvo) filters.
Old 12-06-2005, 10:12 AM
1GreyTeg's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (Splat)
Fram are crap with the minor exception of maybe the EG. Ok there I said it. WIX are rated very well indeed, unfortunately I can never seem to find them. So I bought a case of P1's a year or so ago.
I've used older-larger OEM (Filtech/Toyo Roki) and HAMP (also Toyo Roki), but never the newer OEM filters which are made by FRAM.
I currently use Purolator P1.
Modified by 1GreyTeg at 2:26 PM 12/6/2005
Old 12-06-2005, 10:19 AM
andyt's Avatar
Default Re: WIXvsFRAM OIL FILTER COMPARISON (1GreyTeg)
I like the K&N oil filter, yeah its a little pricey ~$12.00, but its got a "nut" on the end so I can get a normal wrench around it.
I hate oil filter wrenches
Plus I cut open my OEM filter, a FRAM, a Mobil 1, a STP and a K&N...wish I had taken pics...it was pretty amazing to me how different they were on the insides, considering they do the same thing.
Old 12-06-2005, 10:29 AM
Splat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">WIX are rated very well indeed, unfortunately I can never seem to find them.</TD></TR></TABLE>
Looks like mainly independent shops carry WIX filters. Is there a Walker Auto near you?
Old 12-06-2005, 10:34 AM
Default Re: WIXvsFRAM OIL FILTER COMPARISON (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote"> but its got a "nut" on the end so I can get a normal wrench around it.
I hate oil filter wrenches </TD></TR></TABLE>
You can get those socket type things imagine a normal socket only big enough to fit the oil filter with the right ammount of sides, they are used with a 3/8" square end standard ratchet.
Old 12-06-2005, 10:41 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Splat &raquo;</TD></TR><TR><TD CLASS="quote">
Looks like mainly independent shops carry WIX filters. Is there a Walker Auto near you?</TD></TR></TABLE>
Yep I took a look on their site for a dealer locator. Looks like only small private guys and only a few left around me, no Walker Auto. Thanks, now I see a few that may carry some. But it's not a huge deal, I'm satsified with the P1's till their done and that's 4 more changes to go.
Old 12-06-2005, 12:00 PM
.water's Avatar
it has been done manytimes..
wix gold
fram
OEM
Old 12-06-2005, 12:38 PM
projectTeG's Avatar
arent some oem honda filters made by hineywell...which is the same people that make fram? btw ive been using fram oil filters for about 4 years now and had no problems.
Old 12-06-2005, 04:05 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (projectTeG)
Fram? EEEWWW....and some Honda ones are made by Honeywell, some made by Filtech. I only run Filtech Honda filters
Old 12-07-2005, 02:13 AM
WhoisDan's Avatar
Default Re: (Evs-One)
Hamp
OEM
Old 12-07-2005, 02:53 AM
Alexander's Avatar
Default Re: (WhoisDan)
HAMP!
Old 12-07-2005, 07:18 AM
JDMcb7's Avatar
Default Re: (Alexander)
But wait isnt some Honda Oil filters MADE by Fram? and some by honeywell? if you guys are bashing Fram filters are bad.. then why are oem honda filters good?
Old 12-07-2005, 07:26 AM
RagingAngel's Avatar
I use what may be a very little known brand to my American friends....
I suck at the web search right now (can't find pix) but it is made by a company called Altrom. It was recommended to me by a Japanese mechanic who helped start Tom's (Toyota) from what I understand.
I haven't had the chance to cut it open yet but compared to the FRAM made OEM filters in Canada....the bypass valve is metal and the casing is very thick (think Toyo-Roki) and is even painted the same Honda OEM blue.
I suppose the defining feature is that it is made in Japan....
But compared to my factory oil filter (Toyo-Roki - yes from '97) they appear to be identical in every exterior dimension....
I buy them by the half-dozen and it works out to be just under 6bux CAD each.
Old 12-07-2005, 07:33 AM
JDMcb7's Avatar
Default Re: (RagingAngel)
so True! yea altrom is a good brand too as well they are pretty much makers of everything for automotive stuff like rotors and stuff (which im using right now) used it for many track days and yet it still hasnt warped on me yet. but yup your right Altrom is made in the JAPAN ive noticed that too! My Uncles shop uses that too and swears by it...... but i still end up using Honda Honeywell oil filters ( i had like a case of 12) and im down to my last one... i guess after my last one im going to eiter A switch to Altrom or B use Purolator oil filters aka Vavoline which Prelude guys on our local boards swear by them :D
Old 12-07-2005, 08:25 AM
Black R's Avatar
you call that a comparison?
seriously, I use mobil 1 filters and castrol german syntec 0w30.
FRAM is nothing I would even consider.....
Old 12-07-2005, 08:58 AM
Black R's Avatar
Ok, here's some good oil filter tests:
http://www.ntpog.org/reviews/filters/filters.shtml
http://www.mr2.com/TEXT/oil_filter_test.html
http://www.shoclub.com/lubrica...5.htm
http://www.corolland.com/oil-filters.html
http://people.msoe.edu/~yoderw....html
http://www.swri.edu/3PUBS/BROC...t.HTM
http://www.google.com/search?h...+test
Quick Reply: WIXvsFRAM OIL FILTER COMPARISON
