Window Switch
Old Nov 29, 2007 | 06:04 PM
4DRFTW's Avatar
Default Window Switch
Hello, I have a 4 dr gsr, this is type R related because of the parts. Anyways I bought 4 itr db8 door panels, and the two front window switch's. I switched everything over and used the jdm window switch's. The problem is that as soon as I turn the key, all of the window switch fuse's blow. I checked everything over, and the stock one works fine. I would use the stock one but the drivers side switch is broken. Any ideas?
Old Nov 29, 2007 | 06:58 PM
94rs-turbo's Avatar
well either some type of wiring is different(shouldn't be, isnt different with the 2 dr models) or the switch you got has a bad circuit, probably not but those are the only 2 posibilities
Old Nov 30, 2007 | 07:04 AM
4DRFTW's Avatar
Default Re: (94rs-turbo)
Thanks, I opened up the switch it looks ok, but ill take another look.
xfiles
Nov 20, 2014 05:27 AM
Koko4
May 8, 2013 03:54 PM
builthatch
Honda Civic (2006 - 2015)
May 29, 2012 09:38 AM
v-tecnition
Oct 6, 2008 01:19 PM
