Wheel offset question?
Old 08-23-2007, 10:10 AM
cmdr430's Avatar
Default Wheel offset question?
o.k.
I have found a great deal on a set of wheels.....
They are 15x6.5 35 offset
I know people are running 38 offset kosei 15x6.5/7
if I run a 195/55 or 205/50 will it rub on stock height itr?
azenis/hankooks?
Old 08-23-2007, 10:22 AM
BlueIntegraBoy's Avatar
Default Re: Wheel offset question? (cmdr430)
It won't rub at stock height. If you lower it, you might rub your outer wheel well, but never the inner wheel well.
Old 08-23-2007, 10:27 AM
cmdr430's Avatar
Default Re: Wheel offset question? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">It won't rub at stock height. If you lower it, you might rub your outer wheel well, but never the inner wheel well.</TD></TR></TABLE>
yeah, I have come to the conclusion that it should not rub at stock height....
I will probably run a stock tire size of 195/55 maybe a 205/50....
also, my concern is..... If I eventually lower the car on koni yellows and stock springs, I do not want to have to run excessive camber or roll the fenders to eliminate rubbing.....
Old 08-23-2007, 05:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmdr430 &raquo;</TD></TR><TR><TD CLASS="quote">
also, my concern is..... If I eventually lower the car on koni yellows and stock springs, I do not want to have to run excessive camber or roll the fenders to eliminate rubbing.....</TD></TR></TABLE>
In that case, I would run the 195/55.
Old 08-23-2007, 05:12 PM
GO-FIGHT-KILL's Avatar
Are these Chris' wheels, by any chance Cameron?
Old 08-23-2007, 05:15 PM
JjuuN R's Avatar
Default Re: (GO-FIGHT-KILL)
It shouldn't even rub lowered bro...
&lt;--- 15"x7" +33 with 225/45/15 with stock unrolled fenders.
Old 08-23-2007, 09:41 PM
Mr.OB*GYN_Rhett's Avatar
Default Re: (JjuuN R)
and a nice drop too
Old 08-23-2007, 11:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">It shouldn't even rub lowered bro...
&lt;--- 15"x7" +33 with 225/45/15 with stock unrolled fenders.</TD></TR></TABLE>
cmdr430
03-20-2008 07:18 PM
tranzvision
04-10-2006 09:40 AM
Curt941
04-20-2005 08:42 AM
JDM R
08-06-2004 06:04 PM
RedLight_Si
06-04-2004 06:31 AM
Quick Reply: Wheel offset question?
