what is this connector for?
Re: what is this connector for? (flex97itr)
I think it's for the chime. The chime is bolted to the stamped steel plate that covers the bottom of the steering shaft by your knees.
Re: what is this connector for? (sackdz)
hrmm.. are you talking about the door ajar chime when the key is in the ignition? if so the chime still works
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">I think it's for the chime. The chime is bolted to the stamped steel plate that covers the bottom of the steering shaft by your knees.</TD></TR></TABLE>
speaking of which, is that plate "important" ? ... I took it out...
I figure it's for collisions or something.
As for the connector, I don't think mine is connected either.
what colors are the wires?
and the stripes on them. I can look it up in the helms.
also i have a PDF of the helms manual, PM me if you want a copy
without more info here are the 2 pin connectors that it could be:
1. Roof wire harness {C663}
2. Clutch interlock switch
3. Clutch switch (With cruise control)
4. Brake switch without cruise
Modified by twuelfing at 10:14 PM 11/15/2003
