what is this connector for?
http://www.aaronshizouse.homestead.com/files/3plugs.jpg
its the gray connector between the maintenence reset box and #2 |
could be brake switch, chime, maybe optional security stuff that isnt needed in US car..
Re: what is this connector for? (flex97itr)
since it only has 2 wires..I'm guessing some sort of light
whoa, I was just wondering the same thing on my car.....
Re: what is this connector for? (intekragsr)
no one knows?
I think it's for the chime. The chime is bolted to the stamped steel plate that covers the bottom of the steering shaft by your knees.
Re: what is this connector for? (sackdz)
hrmm.. are you talking about the door ajar chime when the key is in the ignition? if so the chime still works
The only way to find out is getting the wiring schematics for that part of the car.
Helms manual, maybe? |
Re: what is this connector for? (Eric's R)
dont have an integra helms https://honda-tech.com/forums/images/smilies/emsad.gif
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz »</TD></TR><TR><TD CLASS="quote">I think it's for the chime. The chime is bolted to the stamped steel plate that covers the bottom of the steering shaft by your knees.</TD></TR></TABLE>
speaking of which, is that plate "important" ? ... I took it out... I figure it's for collisions or something. As for the connector, I don't think mine is connected either. |
what colors are the wires?
and the stripes on them. I can look it up in the helms. also i have a PDF of the helms manual, PM me if you want a copy without more info here are the 2 pin connectors that it could be: 1. Roof wire harness {C663} 2. Clutch interlock switch 3. Clutch switch (With cruise control) 4. Brake switch without cruise Modified by twuelfing at 10:14 PM 11/15/2003 |
Re: (twuelfing)
im thinking it could be clutch switch. there are 2 wires that go to the connector, one is black and one is red
