VTEC Problem!
Old Aug 15, 2004 | 09:28 PM
crx_kid's Avatar
Default VTEC Problem!
I have a 2000 ITR. I have a problem with my motor with the Vtec not working. I have already searched but still couldn't figure out the problem. I have checked my oil and the oil level is fine. I have also checked the Vtec solenoid by giving it 12v and it clicked, so I assume that it's fine right? Then I tried to wired a light to the wire connecting to the solenoid from the ecu to see if the ecu is giving a signal. The light lights up, so I assume that the ecu it working fine, too. The check engine light NEVER came on so I'm guessing that the oil pressure unit is also fine. Also, I checked the oil screen and it's fine as well. And the car was at normal operating temp of course. Therefore, I have no clue of what could be the problem. PLEASE HELP.
Has anyone of you have had a similar problem? Hope you guys can help me out.
Thanks.
Modified by crx_kid at 11:16 PM 8/15/2004
Old Aug 15, 2004 | 09:29 PM
Bbasso's Avatar
Default Re: VTEC Problem! (crx_kid)
Do you have any mods?
Old Aug 15, 2004 | 09:30 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Have a VAFC?
Old Aug 15, 2004 | 09:33 PM
crx_kid's Avatar
Default Re: (Rguy)
no VAFC. I just have an HKS intake and a Spoon N1 muffler. No motor mods.
Old Aug 15, 2004 | 10:07 PM
b19coupe's Avatar
One possible cause-plugged VTEC solenoid screen.
Old Aug 15, 2004 | 10:09 PM
crx_kid's Avatar
Default Re: VTEC Problem! (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">One possible cause-plugged VTEC solenoid screen.</TD></TR></TABLE>
forgot to say that I've checked it already and it's fine.
Old Aug 16, 2004 | 04:00 AM
EuN_TeK's Avatar
I think I'm having the same problem. I was in Korea for 3 months and so my father was driving it around for a while. I came back last week and took her out for a spin and it didn't seem like vtec was kicking in. A few weeks before I got back, my dad took the car for the 30,000 miles maintenance... I have no idea what is wrong with the car.
Old Aug 16, 2004 | 09:36 AM
crx_kid's Avatar
Default Re: VTEC Problem! (EuN_TeK)
can anyone help please?
Old Aug 16, 2004 | 08:33 PM
crx_kid's Avatar
no one has had a similar problem? I tried the tech forum and still really with no help. Hope you ITR guys can help me out. Thanks.
Old Aug 16, 2004 | 08:36 PM
fukthebs's Avatar
wish i could help
Old Aug 16, 2004 | 10:05 PM
integrasi's Avatar
Default Re: VTEC Problem! (fukthebs)
try reset your ecu or take out the battery & put it back on.
Old Aug 16, 2004 | 10:08 PM
Bbasso's Avatar
Default Re: VTEC Problem! (integrasi)
Ya don't have to remove the battery, just disconnect it for a min of 5 mins.
Are your plugs and wires ok along with the distributer cap & rotor?
Don't forget if your air filter is clogged or wet it will prevent the common sounds of vtack...
Old Aug 17, 2004 | 01:00 AM
crx_kid's Avatar
Default Re: VTEC Problem! (Bbasso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Ya don't have to remove the battery, just disconnect it for a min of 5 mins.
Don't forget if your air filter is clogged or wet it will prevent the common sounds of vtack...</TD></TR></TABLE>
yes I've done all of that. cap and rotor are fine. I put new plugs and wires in. Air filter is also new.
accord00z
Oct 17, 2008 03:24 AM
Pleiadi79
Jun 12, 2008 08:22 AM
Phantastic
Nov 13, 2005 11:45 AM
crx_kid
Aug 19, 2004 12:04 AM
navin
Aug 27, 2002 06:45 PM
