Vtec Problem
Old Mar 24, 2004 | 02:58 PM
GSRimport's Avatar
Default Vtec Problem
I have a vtec problem. I had a comptech high flow cat for about 2,000 miles now. When I first put on the cat, the vtec engaged fine. But today, I pushed it and the vtec engaged but it stopped. It was hestitating all the way to redline. I could hear the vtec and it was very loud around 5800-6000 rpm but it stopped after that. It took a very long time to get to redline. This was in first gear. It took longer to get to 30-40 than from 0-30. Please help? I checked my oil level and it was fine. It is in the middle. Thanks in advance.
Old Mar 24, 2004 | 03:07 PM
baonest's Avatar
Default Re: Vtec Problem (GSRimport)
test the solenoid
Old Mar 24, 2004 | 03:08 PM
B2FiNiTY's Avatar
Check your spark plugs, wires, distributer cap and rotor.
Old Mar 24, 2004 | 03:16 PM
110 South's Avatar
This is not an issue with your comptech cat. Most likely there is an issue residing in the distributor i.e. cap/rotor or the housing itself. As B2finity suggested, check your plugs, wires and dist. One quick easy way to test it is just swap out a distributor with one from another GSR..corresponding year.
-Brandon
Old Mar 24, 2004 | 03:34 PM
vtec.dc2's Avatar
1. fill the oil to the top dot.
2. check ignition components, dist. rotor and spark plugs in particular.. - how many miles on these parts?
Old Mar 24, 2004 | 06:04 PM
GSRimport's Avatar
Default Re: Vtec Problem (vtec.dc2)
I have about 10,000 miles on the plugs, wire, and distributor. My cat has failed and it rattles a lot and I have not gotten a check engine light. Thanks for the responses.
Old Mar 24, 2004 | 06:15 PM
Kicker773's Avatar
v-tech solenoid.. n maybe short on oil
Old Mar 24, 2004 | 07:04 PM
GSRimport's Avatar
Default Re: Vtec Problem (Kicker773)
I know where the vtec solenoid is. How do I check if it is functioning correctly? Do I just see if everything is tight and not loose? Thanks.
Old Mar 24, 2004 | 07:38 PM
PlikityPLAH's Avatar
oil change
Old Mar 24, 2004 | 07:59 PM
ITR#132's Avatar
Default Re: Vtec Problem (110 South)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 110 South &raquo;</TD></TR><TR><TD CLASS="quote">This is not an issue with your comptech cat.</TD></TR></TABLE>
Yes it is, I am willing to bet the catalyst material broke apart and is blocking exhaust flow when you hit VTEC. It happens all the time with high flow cats.
Old Mar 24, 2004 | 08:22 PM
GSRimport's Avatar
Default Re: Vtec Problem (ITR#132)
I really hope it is because my cat is really broken right now. It rattles everytime I am idling and no pushing gas while in gear. Thanks for the response.
Old Mar 24, 2004 | 11:12 PM
The Factor's Avatar
Default Re: (PlikityPLAH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PlikityPLAH &raquo;</TD></TR><TR><TD CLASS="quote">oil change</TD></TR></TABLE>
2000SiAddiction
Jul 17, 2011 03:49 PM
JDM_HNIC
24
Jul 13, 2011 08:47 AM
tofu1413
May 15, 2010 03:10 PM
curtisb16
Jul 26, 2007 07:01 AM
Jahtoot84
Jun 21, 2005 06:46 AM
