VTEC problem
Old Aug 14, 2005 | 05:26 PM
SleepingSi's Avatar
Default Vtech problem on my ITR
Ok i searched and couldnt find anything on this. But i have a b18c5 swapped into my si, and vtech used to kick in around 6k. But now it seems that in 1st and 2nd gear it isnt engaging until about 7k and is muffled and isnt as loud as it once was. and in 3rd gear it engages at 6k and is normal loudness but as it climbs up to redline it will cut out. it will be loud then soft then loud then soft. I was thinking maybe a injector or spark plug issue. Has anyone experinced this? and does anyone have any thoughts on what it could be?
Thanks
Old Aug 14, 2005 | 05:29 PM
Chris F's Avatar
Default Re: Vtech problem on my ITR (SleepingSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepingSi &raquo;</TD></TR><TR><TD CLASS="quote">Ok i searched and couldnt find anything on this. But i have a b18c5 swapped into my si, and vtech used to kick in around 6k. But now it seems that in 1st and 2nd gear it isnt engaging until about 7k and is muffled and isnt as loud as it once was. and in 3rd gear it engages at 6k and is normal loudness but as it climbs up to redline it will cut out. it will be loud then soft then loud then soft. I was thinking maybe a injector or spark plug issue. Has anyone experinced this? and does anyone have any thoughts on what it could be?
Thanks</TD></TR></TABLE>
Could be the vtec solenoid, or oil pressure switch. Or, you could be low on oil. Check your oil first.
p.s. spell VTEC correctly. Spelling it VTECH on here, is like going to church and spelling Jeebus wrong.
Old Aug 14, 2005 | 05:40 PM
BS 22's Avatar
Default Re: Vtech problem on my ITR (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">
p.s. spell VTEC correctly. Spelling it VTECH on here, is like going to church and spelling Jeebus wrong. </TD></TR></TABLE>
Give him a break man, he just wants to know what's wrong with his cordless phone
Old Aug 14, 2005 | 06:06 PM
PY TYPE R 483's Avatar
Like Chris F said I would try to check your oil first since vtec needs oil in order to operate properly, and if it is the oil I would definitely keep an eye on this as it normally takes about 2+ quarts of oil missing for vtec to not operate
Old Aug 14, 2005 | 06:09 PM
dsav4shawn's Avatar
Where do all of these B18C5 motors come from??? It seems like every damn civic has one now. It is starting to make me crazy.
Perhaps we should start stealing civics to get the type r motors back??? Just look for a big wing on the back of a civic and it will probally have a type R motor in it.
I was at a car event over in Hampton Va a couple of weeks ago. I saw atleast 10 out of the 100 show cars there with a B18C5 motor (no vins) and they weren't integras.
I hope your stolen motor never works again.
Old Aug 14, 2005 | 06:15 PM
Reid's Avatar
Global Moderator
Default Re: Vtech problem on my ITR (dsav4shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">Where do all of these B18C5 motors come from??? It seems like every damn civic has one now. It is starting to make me crazy.
I hope your stolen motor never works again.</TD></TR></TABLE>
There was a time when other users felt the way you're feeling now.
There are legal and illegal hybrids on this board. But out of courtesy, we give them all the benefit of the doubt, until we can PROVE otherwise.
Old Aug 14, 2005 | 06:25 PM
SleepingSi's Avatar
Well it is probably the oil. when i bought the car a while back the guy told me that it burns about a quart every 1k miles. and it has been 2k miles since my last oil change so I will put 2 quarts in and see if that fixes it.
Old Aug 14, 2005 | 06:33 PM
Chris F's Avatar
Default Re: (SleepingSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepingSi &raquo;</TD></TR><TR><TD CLASS="quote">Well it is probably the oil. when i bought the car a while back the guy told me that it burns about a quart every 1k miles. and it has been 2k miles since my last oil change so I will put 2 quarts in and see if that fixes it.</TD></TR></TABLE>
Be sure not to overfill it. Check on the dip stick when it's level. Don't blindly add 2 quarts.
And yeah, check your oil when you fill up with gas.
Old Aug 14, 2005 | 06:54 PM
SleepingSi's Avatar
just filled the oil up and took it for a spin and the problem is solved. thanks for the help guys.
Old Aug 14, 2005 | 09:09 PM
ITRIK's Avatar
Next time that happens, dont VTEC/Race.. or you'll end up like the last guy blowin his motor.
always check oil level.
Old Aug 15, 2005 | 05:33 AM
dsav4shawn's Avatar
Default Re: Vtech problem on my ITR (Reid)
You're right.... sorry. I need sleep.
Old Aug 15, 2005 | 02:23 PM
VTHokie's Avatar
Jebus, give him a break. The car is my old car, motor is legit, originally the motor was from a 01 itr, the owner noticed it burned oil so he had it replace under warrenty at the time. I knew the dealer at the acura dealership (in newport news) and was able to purchase the long block for very cheap. Motor has had all the piston rings replace, but it still burns a little oil so I suspect the oil burning issue to be a valve seal. Car has been worked on by respectable guys on this board, i.e. Willard and Jack, and is toda equiped. You really should think twice before suspecting someone of stealing chit. Trust me I had a friend that has had his si stolen, last thing I'd want to do is support these fockers and buy a HOT motor.
Old Aug 15, 2005 | 02:32 PM
Brian*'s Avatar
Yeah for real, the motor in that car is way legit. Nice job making an *** out of yourself though sport
Brian
Old Aug 15, 2005 | 03:21 PM
Chris F's Avatar
Default Re: Vtech problem on my ITR (Brian*E30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian*E30 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah for real, the motor in that car is way legit. Nice job making an *** out of yourself though sport
Brian</TD></TR></TABLE>
I had to read that post and the previous post like 3 times to figure out if you were bleeding with sarcasm like "Yeah right, it's WAY legit"... depends on who you were replying to, which isn't shown.
Cliffs: legit.
Old Aug 15, 2005 | 03:54 PM
Brian*'s Avatar
Haha yeah, no sarcasm, the motor is clean. My rep for extreme sarcasm set a precedent for me . Eric's been a friend for quite a few years, good guy, even though he has big chicken strips
Brian
Old Aug 15, 2005 | 04:42 PM
VTHokie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brian*E30 &raquo;</TD></TR><TR><TD CLASS="quote">Haha yeah, no sarcasm, the motor is clean. My rep for extreme sarcasm set a precedent for me . Eric's been a friend for quite a few years, good guy, even though he has big chicken strips
Brian
Chicken strips? Whatever can you be talking about
Modified by VTHokie at 9:59 PM 8/15/2005
Old Aug 16, 2005 | 12:37 AM
dsav4shawn's Avatar
Sorry if offended. More or less was directed to the other questionable motors I've seen. Just wondering if anyone else finds it as amazing that there are so many civics with ITR parts(engines)? I guess it's just a popular motor that is so readily available at your local parts store. Just frustrated with all of the stolen car threads and attemted thefts I've heard about. Tired of wanting to be normal and not worry constantly about where and when my car will be stolen. Good luck getting your legit motor running right.
Old Aug 16, 2005 | 02:39 AM
Sehc Tib Alli Zerif!!!!!'s Avatar
cool guy name
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">Sorry if offended. More or less was directed to the other questionable motors I've seen. Just wondering if anyone else finds it as amazing that there are so many civics with ITR parts(engines)? I guess it's just a popular motor that is so readily available at your local parts store. Just frustrated with all of the stolen car threads and attemted thefts I've heard about. Tired of wanting to be normal and not worry constantly about where and when my car will be stolen. Good luck getting your legit motor running right. </TD></TR></TABLE>
Get used to it, cause it will never end. I've been on this board from almost the beginning and its always been here.
808k20z3
Honda Civic (2006 - 2015)
Jan 21, 2007 10:55 AM
NerveAgent
Honda S2000
Feb 6, 2006 01:35 AM
kseriesDC5
14
Feb 16, 2004 04:52 PM
VTECLuDe96
Oct 8, 2003 08:09 PM
YelLowITR
Apr 22, 2003 04:17 PM
