value clearance
Old Apr 3, 2003 | 09:37 PM
typerfans's Avatar
Default value clearance
I have tried the search function, but I got nothing....
can anyone give me a quick answer to this question: what is the value clearance for the stock 00 ITR? I am doing the value adjustment now, and I lost the factory manual....
any help would be appreciate, thank you
Old Apr 3, 2003 | 09:44 PM
VTHokie's Avatar
Default Re: value clearance (typerfans)
.006 intake
.007 exhaust
Eric
Old Apr 4, 2003 | 02:27 AM
typerfans's Avatar
Default Re: value clearance (VTHokie)
thank you very much!!!
Old Apr 4, 2003 | 05:16 AM
b19coupe's Avatar
.006 intake
.007 exhaust
And the spec is cold, if you did not already know.
Old Apr 4, 2003 | 05:45 AM
TypeR 01 886's Avatar
How touch is it to do that with the correct tools? I want to do it but i dont want to fugg my motor either!
Old Apr 4, 2003 | 06:19 AM
VTHokie's Avatar
Default Re: value clearance (b19coupe)
.006 intake
.007 exhaust
Yep, do the adjustment cold. Doing a valve adjustment is not that hard, but it will be alot easier with the snap on valve adjustment tool.
Here are directions on how to do the adjustment. http://www.c-speedracing.com/howto/v...alveadjust.php
Old Apr 4, 2003 | 08:50 AM
py1188's Avatar
great piece...worth it if you plan to do your own valve adjustments
Old Apr 4, 2003 | 09:11 AM
typerfans's Avatar
Default Re: value clearance (py1188)
yup, that's what we are using...
doing the value adjustment isn't hard, but it needs a lot of time and patience to make it right for the first time.
Old Apr 4, 2003 | 09:26 AM
NewR's Avatar
When do you adjust your valves clearance? The manual says to adjust it when it is noisy and also required at 60K or 90K (not sure). Mine has 28K, do I need to them adjusted?
Thanks.
Old Apr 4, 2003 | 09:30 AM
Eva01's Avatar
Default Re: value clearance (NewR)
Maintenace schedule recommends checking valve lash every 15K. But doing a valve adj every 30k is probably sufficient. It's a back killer but other than that not tough at all.
Old Apr 4, 2003 | 11:42 AM
deepgreengsr's Avatar
Default Re: value clearance (Eva01)
the lash vlaues should also be on the sticker under your hood.
Old Apr 4, 2003 | 11:50 AM
sgT's Avatar
sgT
Default Re: value clearance (deepgreengsr)
ummm, it should be .007 int and .008 exh
Old Apr 4, 2003 | 12:41 PM
Dave-ROR's Avatar
Default Re: value clearance (sgT)
Well, technically..
.006-.007 intake
.007-.008 exhaust
Old Apr 4, 2003 | 12:47 PM
sgT's Avatar
sgT
Default Re: value clearance (dawhiteboy)
thats why i use .17mm and .19mm as my specs. std is too broad
Old Apr 4, 2003 | 01:00 PM
b19coupe's Avatar
Service manual says: Intake-0.15-0.19mm (0.006-0.007 in)
Exhaust-0.17-0.21mm (0.007-0.008 in)
I use a 0.007 in feeler guage for intake =0.178mm.
And a 0.008 in feeler guage for exhaust=0.203mm.
Old Apr 4, 2003 | 01:29 PM
turbosol's Avatar
Do any of you run your valve lash tighter than spec?
Old Apr 4, 2003 | 01:33 PM
Dave-ROR's Avatar
Default Re: value clearance (turbosol)
I don't.
crash my EG
Mar 1, 2007 02:13 PM
bigdaddyradde
May 13, 2006 12:05 PM
bocian
Dec 19, 2002 08:17 AM
bocian
Feb 12, 2002 08:40 PM
tjtruong
Oct 27, 2001 10:29 PM
