Tranny problem.....HELP
Old May 3, 2003 | 10:43 AM
JDM97R's Avatar
Default Tranny problem.....HELP
I have a jdm itr and i have a centreforce clutch installed for about a year now and i use it for drag racing. The problem is when i try to put it in first gear ,it's very hard to shift it. I need to know if the problem is the tranny( synchros) ,the oil or the pressure plate?
Modified by MIG-VTI at 9:17 PM 5/3/2003
Modified by MIG-VTI at 10:22 AM 5/4/2003
Old May 3, 2003 | 11:08 AM
RTW DC2R's Avatar
Default Re: Tanny problem.....HELP (MIG-VTI)
"tanny" lol
This happens only in first gear?
Old May 3, 2003 | 11:16 AM
JDM97R's Avatar
Default Re: Tranny problem.....HELP (CACK ***!)
Most probably yes cause when the first gear is in , all gears are ok
Old May 3, 2003 | 11:49 AM
JDM97R's Avatar
Default Re: Tranny problem.....HELP (MIG-VTI)
Any help please?
Old May 3, 2003 | 12:26 PM
Stinkycheezmonky's Avatar
Suspetise...
I really don't know enough about transmissions, but I'd say it's not synchros, as they just make the gear engagement smoother (I think, to simplify in a huge way there). Does it grind when you put it into first? If it does, then I could be wrong and it could be the synchros. What do you mean about oil? Transmission fluid? And I don't think the pressure plate would make it hard to engage the gear, unless when the clutch pedal is fully depressed, the clutch itself is not fully disengaged.
Old May 3, 2003 | 01:05 PM
JeffS's Avatar
I'd guess a bent shift fork.
Old May 3, 2003 | 11:14 PM
JDM97R's Avatar
Default Re: Tranny problem.....HELP (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">I really don't know enough about transmissions, but I'd say it's not synchros, as they just make the gear engagement smoother (I think, to simplify in a huge way there). Does it grind when you put it into first? If it does, then I could be wrong and it could be the synchros. What do you mean about oil? Transmission fluid? And I don't think the pressure plate would make it hard to engage the gear, unless when the clutch pedal is fully depressed, the clutch itself is not fully disengaged.</TD></TR></TABLE> Yes i meant the trans fluid and the first gear doesn't grind to get in.Also this happens to me when i 'm in a traffic jam and i have to press alot the clutch pedal.Thanks for your information.
Old May 4, 2003 | 09:43 AM
JDM97R's Avatar
Default Re: Tranny problem.....HELP (JDM97R)
Some ideas please of what to do
Old May 4, 2003 | 12:08 PM
Audipwr1's Avatar
is the car moving when ur trying to get it into first?
if yes you must double clutch to go from second to first, or be patient and gently keep pressure on the stick
if no
change your fluid and see how that treats you
Old May 4, 2003 | 03:19 PM
Suspetise...
Default Re: Tranny problem.....HELP (Audipwr1)
I'd also agree with JeffS and Audipwr. The fluid is an easy fix, just to check and/or change. If it comes down to it, opening the tranny to check the shift forks probably won't be easy or cheap, unless you can do that kind of thing yourself.
SpoonCivicSir20
Oct 13, 2008 08:13 AM
jdmjunkieXL
27
Feb 22, 2007 09:24 AM
zracer240
Jul 21, 2005 12:15 AM
ludevtec93
Oct 19, 2001 12:26 PM
